How Do You Calculate Reaction Forces in Static Equilibrium?
The discussion revolves around calculating reaction forces in a static equilibrium problem involving a plate subjected to a force and multiple reaction forces. Participants explore the application of equilibrium equations and the determination of moments about a point.
  • Homework-related
  • One participant presents equilibrium equations for horizontal and vertical forces, as well as moments, to find the reaction forces R1, R2, and R3.
  • Another participant agrees with the calculated value of R3 as 70 kN and provides an alternative approach to the moment calculation, confirming R1 = R2.
  • There is a question regarding the sign convention for moments, specifically how to determine the direction (anticlockwise/clockwise) of the moments in the calculations.
  • A suggestion is made to verify the correctness of the calculations by taking moments about a different point, ensuring the sum remains zero.
Participants generally agree on the value of R3 and the relationship between R1 and R2. However, there is some uncertainty regarding the moment calculations and the sign conventions used.
Participants express uncertainty about the correctness of their moment calculations and the determination of moment directions, indicating potential limitations in their assumptions or definitions.
Students and individuals studying static equilibrium problems in physics or engineering may find this discussion relevant for understanding the application of equilibrium equations and moment calculations.
Kasthuri
Question: The plate shown, picture is attached, is subjected to force F and 3 reaction forces R1 R2 R3. Find R1
equations of equilibrium:
sum of Fx = 0
sum of Fy = 0
sum of moment about point O = 0
sum of Fx = 0: (going right is positive)
-R1 - R2 + 3/5 R3 = 0
sum of Fy = 0: (going up is positive)
-56kN + 4/5 R3 = 0
so, R3 = 70kN
sum of moment about point O = 0 (going anticlockwise is positive)
R1 x (0.11m) - R2 x (0.11m) = 0
so, R1 = R2
therefore, R1 = R2 = 21kN
I am unsure of whether I have done this question correctly, in particular the moment about O.
Also, how do you figure out which direction the moment is in (anticlockwise/clockwise). As in, I took R1 x 0.11m as positive due to anticlockwise and
R2 x 0.11m as negative due to clockwise moment.
is this correct?
Thanks for any help you can offer!
R3=70Kn appears correct.
As for the moment...
R1*110 + (-R2*110) = 0
So
R1 = R2
Both same sign
Horizontally, if left is positive...
-R3*3/5 + R1 + R2 = 0
-R3*3/5 + R1 + R1 = 0
-R3*3/5 + 2R1 = 0
R1 = R3*3/(5*2)
= 21kN
which is a +ve number so to the left.
R1 = R2
so R2 also to the left.
Thank you!
To check whether you are correct, just take moments about any other point. The sum should be zero.
