Model Dynamics of Unit Mass Sliding Down y=f(x) Under Gravity
This thread discusses the dynamics of a unit mass sliding down a curve defined by the function y = f(x) under the influence of gravity. The focus is on analyzing the forces acting on the mass, particularly in the context of friction and the geometry of the curve. Participants explore various cases and the implications of different parameters on the motion of the mass.
  • One participant describes the forces acting on a unit mass sliding down a curve, including gravitational force, normal force, and frictional force, and presents a vector analysis of these forces.
  • Two cases are presented with specific values for gravitational acceleration and kinetic friction, leading to different dynamics for the mass in each case.
  • Participants discuss the implications of the direction of the friction force in relation to the gravitational force and the slope of the curve.
  • One participant identifies a potential error in their derivation related to the angle used in calculating forces, suggesting that signed angles may lead to complications.
  • Another participant suggests using a multi-parameter version of the tangent function to avoid issues with lost information in angle calculations.
  • Concerns are raised about the relationship between acceleration components and the curvature of the path, particularly at points where the second derivative of y with respect to x is non-zero.
  • Participants discuss the necessity of normal acceleration for motion along a curved path and the role of centripetal force in this context.
There is no consensus on the specific flaw in the model or the implications of the findings. Participants express differing views on the calculations and interpretations of forces, and the discussion remains unresolved regarding the correct approach to modeling the dynamics of the mass.
Participants note limitations in their models, including potential errors in angle calculations and the need for absolute values in certain contexts. The discussion includes unresolved mathematical steps related to the curvature of the path and the behavior of acceleration components.
LuculentCabal
For a unit mass sliding down the stationary curve [itex]y = f(x)[/itex] at the point [itex](x, y)[/itex], we can consider our mass to be sliding down a stationary inclined plane which is tangential to the curve at the point [itex](x, y)[/itex]. The slope of this inclined plane is thus [itex]\frac{dy}{dx}(x)[/itex].
For the remainder of this thread, [itex]y'[/itex] means [itex]\frac{dy}{dx}[/itex]
For the purposes of this exercise, I want the coefficient of static friction to be zero.
Let [itex]\mu_k[/itex] be the coefficient of kinetic friction
Let [itex]g[/itex] be the acceleration due to gravity
Let [itex]\vec{F_g} = mg[/itex] be the force exerted on our unit mass due to gravity.
Let [itex]\vec{F_{||}}[/itex] be the force exerted on our mass parallel to the plane.
Let [itex]\vec{F_\bot}[/itex] be the force exerted on our mass perpendicular to and into the plane.
Let [itex]\vec{F_N} = - \vec{F_\bot}[/itex] be the force exerted on our mass perpendicular to and out of the plane .
Let [itex]\vec{F_f} = \mu_k \vec{F_\bot}[/itex] be the force of friction which resists [itex]\vec{F_{||}}[/itex]
Then [itex]\vec{F_Ʃ} = \vec{F_{||}} + \vec{F_f} + \vec{F_\bot} + \vec{F_N}[/itex] is the net force exerted on our mass. This is our objective.
From the vector analysis, I have found [itex]\vec{F_Ʃ}[/itex] to be given by:
[itex]\frac{1}{g} \vec{F_Ʃ} = [cos(θ) sin(θ) - \mu_k cos^2(θ)] \ \hat{i} + [sin^2(θ) - \mu_k cos(θ) sin(θ)] \ \hat{j}[/itex]
Where:
[itex]θ = tan^{-1} (y')[/itex]
The model behaves as expected whenever [itex]\mu_k[/itex] = 0.
However, consider the trivial cases 1. and 2. below:
Case 1.
[itex]\ \ \ g = -9.81[/itex] // arbitrarily
[itex]\ \ \ \mu_k = 0.5[/itex] // arbitrarily
[itex]\ \ \ y = x[/itex] // the standard inclined plane
Case 2.
[itex]\ \ \ g = -9.81[/itex] // same as Case 1.
[itex]\ \ \ \mu_k = 0.5[/itex] // same as Case 1.
[itex]\ \ \ y = -x[/itex] // this is simply observing Case 1. from the other side of the plane
These parameters result in the following dynamics:
Case 1.
[itex]\ \ \ \frac{d^2 x}{d t^2} = -2.4525[/itex]
[itex]\ \ \ \frac{d^2 y}{d t^2} = -2.4525[/itex]
Case 2.
[itex]\ \ \ \frac{d^2 x}{d t^2} = 7.3575[/itex]
[itex]\ \ \ \frac{d^2 y}{d t^2} = -7.3575[/itex]
For the previous cases, my intuition told me to expect the following:
a) That the sign on the horizontal acceleration would be negative in Case 1. and positive in Case 2.
b) That the sign on the vertical acceleration would be negative in Case 1. and negative in Case 2.
c) That the magnitude of the horizontal acceleration in Case 1. would be equal to the magnitude of the vertical acceleration in Case 1.
d) That the magnitude of the horizontal acceleration in Case 2. would be equal to the magnitude of the vertical acceleration in Case 2.
e) That the magnitude of horizontal and vertical acceleration in Case 1. would be equal to those of Case 2.
As we can see, the results are in agreement with a), b), c), d). However, hypothesis e) has failed.
Question:
What is the flaw in the model (or hypothesis e) ) that made the results diverge from e) when [itex]\mu_k[/itex] was non-zero (holding all other parameters constant)?
**If it is helpful, I can post my derivation of [itex]\vec{F_Ʃ}[/itex] in a followup.**
In case 2, your friction force has the same direction as the component of gravity parallel to the plane.
Hi willem2. Thanks for pointing that out.
In trying to find out why that is the case, I found an angle error in my derrivation of the force of friction. I hope this is the only bug...
Well it seemed like a good idea, but it appears as though we can't have signed angles
ie [itex]θ ≠ tan^{-1}(y')[/itex] but rather [itex]θ = |tan^{-1}(y')| = tan^{-1}(|y'|)[/itex]
That's sounds like a classic inverse trig obstacle that we encounter all the time in computer science (I'm a programmer by trade).
Have you considered using the multi-parameter version of the tangent function?
i.e. arctan(x, y) rather than arctan(y/x)
It's used in programming libraries to correct the deficiencies of the traditional arctan. arctan(y/x) essentially loses some of the information of the system. Human beings will often subconsciously reinsert lost information into the system when they use arctan(y/x) by hand, if my memory is correct.
Also, there are other ways of finding the normal vector than using trig. For example, in 2 dimensions you can convert a vector to a complex number (x = real component, y = imaginary component) and then multiply by i in order to rotate the vector by 90 degrees to get the normal vector. Quaternions can achieve a similar function for 3 dimensions I believe, from what I've heard.
Hope that helps. I only glanced over the other parts of your post but these few things caught my eye quick.
Thank you for taking the time to offer your suggestions WraithGlade.
Unfortunately the problem with the model that I have presented is that displacement instead of distance was used for the purpose of determining theta. It is because of this that I am getting signed angles which are problematic for the sine function being that it is odd. It looks inevitable that fixing this bug is going to introduce some form of absolute value function.
I will have to play around with it now to solve for x(t). However, it looks like Newton-Raphson will still be king at the end of the day!
You mean, that component of gravity, yes?
This one is exerted by the wire, yes?
They're only going to be equal and opposite if the acceleration is parallel to the wire.
Where the wire is curved, there will be acceleration normal to the wire.
I note the equation you end up with has no term involving y'', which cannot be right.
Hello haruspex. Thank you for your review.
Yes, [itex]\vec{F_\bot}[/itex]is due to gravity.
I would be grateful if you (or someone) could explain why our mass would experience acceleration normal to the curve on the points where [itex]\frac{d^2 y}{dx^2} ≠ 0[/itex].
I had imagined that at the point (x,y), our mass would experience acceleration parallel to a tangent at the point (x,y). As our mass moves instantaneously along the curve, our tangent would be instantaneously changing too as it moves along with the mass. Why is this not the case?
Well, as for arbitrary two dimensional curvilinear motion, the acceleration components are:
[tex]a_{n}=\frac{v^2}{r}[/tex]
[tex]a_{t}=\frac{dv}{dt}[/tex]
The first refers to the acceleration components normal to the tangent and thus the second refers to the acceleration components parallel to the tangent.The r is radius of curvature, which, for an arbitrary two dimensional curve, has a specific formula for it.So here you may see that you have to know the velocity of the mass so as to get the [itex]a_{n}[/itex]
Just to add a little to what azureth wrote:
Acceleration in the direction of travel will change the speed but not the direction. To travel along a curve requires a component of acceleration normal to the velocity, a centripetal force.
Sorry guys, but I have no idea how to find v if all that I know is y(x), g, mu_k, and the initials v0, x0. It seems v cannot be found without first either knowing x(t) or F_x(t) and neither x(t) or F_x(t) can be found without knowing v...
Because there is friction involved, I think you have to start with the acceleration equations. Otherwise you could have used the energy equation to relate y and v.
If by "sliding" you really mean that the mass can move only along the curve, it would be easier to consider the parametric representation of the curve, [itex]x = x(s), y = y(s)[/itex], where [itex]s[/itex] is the length along the curve. Then what you would need to find is [itex]s = s(t)[/itex]. The magnitude of the velocity at any point is [itex]\dot{s} = \frac {ds}{dt}[/itex], so [itex]m\ddot{s} = F_{\tau}[/itex], where the entity on the right is the tangential component of the net force. [itex]F_{\tau} = G_{\tau} - R[/itex], where [itex]G_{\tau}[/itex] is the tangential component of the gravitational force, and [itex]R[/itex] is the magnitude of the force of friction. [itex]R = \mu_kN[/itex], where [itex]N[/itex] is the magnitude of the reaction force. The reaction force is always normal to the trajectory, so [itex]ma_n = N[/itex], where [itex]a_n[/itex] is the normal acceleration. Now, [itex]a_n = v^2\kappa[/itex], where [itex]v[/itex] is the magnitude of the velocity and [itex]\kappa[/itex] is the curvature, so [itex]R = \mu_k m \dot{s}^2 \kappa = \mu_k m \dot{s}^2 \left| x'y'' - y'x'' \right|[/itex]
Continuing, [itex]G_{\tau} = - mg sin \theta = -mg y'[/itex]. Putting everything together: [tex]m\ddot{s} = -mg y' - \mu_k m \dot{s}^2\left|x'y'' - y'x''\right|[/tex]
Let's see how that works for a unit circle. [itex]x = cos(s), y = sin(s)[/itex]. Then:[tex]\ddot{s} = -g cos(s) - \mu_k m \dot{s}^2[/tex] In the vicinity of [itex]s = \frac {3 \pi } {2}[/itex], [itex]cos (s) \approx s[/itex], and assuming small velocities [itex]\dot{s}^2 \approx 2\dot{s}[/itex], thus [tex]\ddot{s} + 2\mu_k \dot{s} + gs = 0[/tex] which is the well-known equation of damped harmonic oscillations, as is to be expected physically.
  • · Replies 41 ·
  • · Replies 29 ·
