How Small Can a Pulse Be Detected with a 1GHz Oscilloscope?
  • Thread starter Thread starter fedeb1
    Resolution Time
The discussion revolves around the detection of small pulses using a 1GHz bandwidth oscilloscope, focusing on the relationship between bandwidth and time resolution. Participants explore various aspects of pulse measurement, including theoretical foundations and practical considerations.
  • One participant inquires about the smallest detectable pulse and seeks a formula linking bandwidth to time resolution.
  • Another participant states that there is no general formula applicable to all pulse types, emphasizing that the frequency of the waveform affects the measurement outcome.
  • A participant explains that a pulse in the time domain corresponds to a sinc function in the frequency domain, noting that shorter pulse widths require higher bandwidth for accurate representation.
  • One participant shares a specific formula relating rise time to bandwidth: t_{rise} = 0.35/f_{bw}, suggesting that this is a more relevant relationship than pulse width.
  • Another participant cautions that the rise time to bandwidth relationship is valid primarily for oscilloscopes with a Gaussian-like response.
Participants express differing views on the applicability of formulas for pulse detection, with no consensus on a single formula or method that universally applies to all scenarios discussed.
Participants note the importance of defining acceptable distortion levels when measuring pulses and the potential impact of aliasing in digital oscilloscopes. There is also mention of variations in how different sources present the sinc function.
fedeb1
Hi,
What is the smallest pulse i can see using an oscilloscope with 1GHz bandwidth?
Im interested in the formula that links bandwith and smallest time resolution. Also it would be nice if you could include the reference of where i could read and learn about this things.
Thanks and sorry for my english.
There isn't any such general formula. If by pulse you mean square wave, it will depend on the frequency of the waveform.
The oscilloscope is effectively a filter. If you measure a square wave of low frequency relative to the bandwidth of the oscilloscope, you'll pass through the fundamental and plenty of it's harmonics, so you'll get to view a nice representation of the waveform. If the frequency of the square wave is close to the bandwidth of the oscilloscope, you'll probably just see the fundamental, as shown here:
Square wave frequency spectrum animation
This will make more sense if you read up a bit on 'Fourier series'. You can find plenty of good intuitive tutorials on it with a Google search.
A pulse in the time domain is a sinc function in the frequency domain. The spacing between sinc peaks and the amount of energy in each sinc peaks is related to the pulse width. A shorter pulse width will mean more energy in higher frequencies. A sinc spectrum is infinite, so a pulse requires infinite bandwidth to perfectly recreate, and so you will get a more distorted pulse measurement as you apply shorter pulses to the scope.
You need to define how much distortion you will accept in your pulse (how much energy you want under the sinc curve), then use that limit at 1GHz (but if digital scope take into account aliasing) and inverse Fourier transform to get the pulse width.
fedeb1 said:
Hi,
"Smallest pulse I can see" is not a good way to link bandwidth with time resolution. For example, if the pulse amplitude is actually 1V, but it shows up as a 1uV bump on the oscilloscope would this count?
Instead, we connect the risetime with the oscilloscope bandwidth, and the most common formula is:
[tex]t_{rise} = 0.35/f_{bw}[/tex]
Do Internet search for "risetime and bandwidth and oscilloscope" and you will find many dozens of papers on this.
I was looking for that last formula. Trise and bandwith and i don't know why i thought it was pulse width and bandwith.
Thanks for all the replies!
Just keep in mind, that relationship only applies if your oscilloscope exhibits a Gaussian-like response, which is common for analog scopes:
Relating wideband DSO rise time to bandwidth
If you're pushing the limits of your scope, DragonPetter suggested a better way to evaluate signal distortion.
24K
  • · Replies 16 ·
12K
  • · Replies 20 ·
