Electricity generation - simple bike dynamo - can anyone explain this design?
The discussion revolves around the design and function of a bike dynamo, specifically focusing on the role of the soft iron core in electricity generation. Participants explore the principles of electromagnetic induction and the efficiency of the dynamo's operation.
  • One participant questions the necessity of the soft iron core, suggesting that the dynamo should function with just the rotating magnet and coils.
  • Another participant argues that the soft iron core increases magnetic permeability, concentrating magnetic field lines and enhancing the magnetic flux through the coil.
  • It is proposed that without the iron core, the dynamo would still generate some electricity, but less efficiently.
  • A participant expresses confusion about how the stationary wires can receive voltage from the rotating magnet, indicating a need for clarification on the principles of electromagnetic induction.
  • One participant clarifies that the dynamo uses a spinning magnet rather than an electromagnet, emphasizing the role of Lenz's Law in the generation of voltage.
  • Another participant notes that while the iron core may not be strictly necessary, it improves efficiency, allowing for less effort in pedaling to achieve the same output.
  • The importance of changing magnetic flux to induce current is highlighted, with the core's role being to concentrate that flux.
Participants express differing views on the necessity and role of the soft iron core, with some asserting its importance for efficiency while others question its essentiality. The discussion remains unresolved regarding the core's necessity for basic operation.
There are unresolved questions about the relationship between the stationary wires and the rotating magnet, as well as the specific conditions under which the dynamo operates effectively.
Steve143
http://img404.imageshack.us/img404/9523/dynamos.jpg
I understand that when the rotating magnet spins, current should be induced in the coils which powers the lights.
So what is the point of the soft iron core? The rotating magnet should magnetise it because it is near it, and it should become an electromagnet when current flows through the wire, but I can't see a point to any of this. I would think the design should work even if you replaced the soft iron core with a piece of wood because I think all you really need is for the magnet to spin near the wires for the electricity you need.
The soft iron has a very high magnetic permeability and essentially the magnetic field lines are concentrated (or focused) within it. So the magnetic flux through the coil is much larger with the soft iron present than if you were to replace the soft iron with a non-magnetic material like wood. You might start reading here.
The point of the core is to maximize the magnetic flux through the center of the solenoid.
Without it, there would still be some flux through the coil - just not as much, so you won't get as much electricity for the speed.
I see, so the rotating magnet is not strong enough to power the lights on its own which is why the iron core is needed.
However the iron core and the wires are not moving moving relative to each other (From the picture it looks like the rotating magnet spins but everything else remains in place) which I believe is a requirement for current generation, so how does this electromagnet supply the wires wrapped around it with voltage?
Hi Steve
its not an electromagnet...
An electromagnet is a coil with an iron core that YOU supply voltage to to generate a magnetic field
The bike dynamo aka generator uses a spinning magnet in a iron cored coil to induce a voltage into the coil
have a look at Lenz's Law ... http://en.wikipedia.org/wiki/Lenz's_law[/PLAIN]
cheers
Dave
It may or may not be needed - but the iron core makes the generator more efficient - so you don't have to pedal as hard to get the same speed.
Note: you only need a changing magnetic flux through the coils to induce electric current - the flux changes as the position of the rotating magnet changes. The effect of the core is to concentrate that flux.
Try sketching the flux lines from an overhead diagram of the setup.
  • · Replies 17 ·
