What is the value of Ts in seconds?
The problem involves calculating the value of Ts, which is defined in terms of a formula involving mass and force. The context is rooted in physics, specifically in the area of oscillations or harmonic motion.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to simplify the expression for Ts but expresses confusion regarding the units involved, particularly the kg/s² term. Some participants suggest examining the cancellation of units and re-evaluating the mathematical steps taken.
Participants are actively engaging with the problem, providing guidance on unit cancellation and the implications of square roots in the context of the formula. There is an ongoing exploration of the correct interpretation of the units and the mathematical operations required.
There is a noted confusion regarding the dimensional analysis of the terms involved, particularly the interpretation of kg/s² and its role in the calculation of Ts. Participants are also addressing potential mistakes in the simplification process.
DLHill
Ts (subscript s) = 2∏*√(4.5*10^-2 kg / 2.0*10^3 kg/s^2)
kg = Kilograms
s = seconds
Ts = ?
I do not have any relevant questions.
Ts = 2∏*√(4.5*10^-2 kg)/√(2.0*10^3 kg/s^2) Simplified
Ts = 6.28*[(0.212 kg)/√(44.72 kg/s^2)] Simplified
I am not sure what to do past this step. I don't think i could cancel out the kg because I would have only s^2 on the bottom. I have never seen a unit like kg/s^2, so I am confused. Does that unit even make sense? Any help is appreciated.
You are on the right lines. Consider this bit..
You have kg top and bottom so they cancel giving
4.5*10^-2 / 2.0*10^3 /s^2
Then multiply top and bottom by s^2 giving
s^2 (4.5*10^-2 / 2.0*10^3)
Now put that back into your equation giving...
Ts = 2∏*√( s^2 (4.5*10^-2 / 2.0*10^3))
What does √(s^2) equal?
See the dimensions work out just fine.
Oh I think I understand now, so would Ts = 2(pi)*sqrt(0.005)s^2 = 2(pi)*0.0707s = 0.443s?
I think you have done sqrt twice by mistake.
Oh, I just saw that. Thanks. So 2(pi)*(0.005)s^2?
No now you forgot to sqrt the s^2 part
Ts= 2(pi)*(0.005)s
