New Reply
swl of a motor
Share Thread
Aug7-12, 12:21 PM   #1
swl of a motor
using the following information can anyone tell me if the detailed motor is capable of lifting 90kgs 48"
Nominal speed 40 rpm
Nominal torque 5 Nm
Nominal voltage 12 V
Shaft diameter 9 mm
Manufacturer part no. DO 111.3761.2B.00 / 3018
Specification DC gear motor
Nominal current 5 A
Shaft design With key 3
Type DO11137612B00/3018
http://www.conrad-uk.com/ce/en/produ...01101&ref=list
regards
red
PhysOrg.com engineering news on PhysOrg.com
>> Mathematical algorithms cut train delays
>> Researchers design software to detect changes in colour vision
>> Trend study identifies potential for humans and technology to interact in a manufacturing environment
Aug7-12, 03:47 PM   #2
Mentor
Depends on how fast you want to lift it.
Aug7-12, 03:50 PM   #3
takes about about 10-15 seconds with current motor
Aug8-12, 01:51 AM   #4
swl of a motor
Describe the lift mechanism (i.e., rope on a drum, like a winch), including dimensions.
Aug8-12, 03:30 AM   #5
Quote by pantaz View Post
I will be using nylon tape 25mm wide which coils onto a small drum approx 30mm i/d 75mm o/d
http://www.bruno.com/vehicle-lift-take-apart-lifts.html
this the hoist mechanism
Aug13-12, 11:47 AM   #6
any ideas people? trying to save a disabled guy £450
Aug14-12, 06:12 AM   #7
Your downward force is 90*9.81 N (call it 900) so if your drum is .037 m radius you need a torque of 33.3 NM so you'd need a 7:1 reduction gearbox.
To raise 90 Kg over 1.2 M you need about 1000 J, 12V*5A is 60w so it would take slightly over 15 seconds for the lift.
Aug14-12, 04:25 PM   #8
thanks jobrag
thats brilliant
Sep20-12, 07:30 AM   #9
Recognitions:
Gold Membership Gold Member
Jobrag,
I have a question please. If this was an application with a rope wrapped around the drum, would we not consider the diameter of the rope in addtion to the radius of the drum to back calculate the force necessary?
New Reply
Similar discussions for: swl of a motor
Thread Forum Replies
Does the current drawn by an electric motor increase or decrease as the motor starts Introductory Physics Homework 5
driving a compact can crusher- stepper motor or gear motor? Mechanical Engineering 12
winding resistance of large motor vs small motor Mechanical Engineering 2
Electromagnetic Motor (Simple Motor) & Voltmeters Advanced Physics Homework 6
Can DC motor works as a stepper motor? Electrical Engineering 1
