What is the Entropy of Liquid Nitrogen at 77.244K and 1bar Pressure?
The discussion revolves around determining the entropy of liquid nitrogen at 77.244K and 1 bar pressure. Participants explore various methods and approximations to estimate this value, discussing the challenges of finding reliable data below 100K.
  • One participant notes difficulty in finding entropy values for liquid nitrogen below 100K and seeks guidance on where to find this information.
  • Another participant suggests an approximation method to estimate entropy using specific heat and logarithmic relationships, emphasizing the need for caution with extrapolations.
  • A correction is made regarding the initial claim about having the entropy of nitrogen gas instead of liquid nitrogen at 100K, highlighting the phase change implications on entropy.
  • One participant proposes a rough approximation of liquid nitrogen's entropy as 120 J/moleK, derived from a proportionality method, but acknowledges uncertainty in this approach.
  • Another participant challenges the validity of the proportionality method and suggests a more detailed calculation involving the heat of vaporization and specific heats for both gas and liquid nitrogen.
  • References to specific values for specific heats and heat of vaporization are provided, along with a suggestion to consult the NIST database for further information.
Participants express differing views on the methods to estimate entropy, with some supporting the use of approximations while others advocate for more rigorous calculations. There is no consensus on the best approach or the exact value of entropy for liquid nitrogen at the specified conditions.
Participants note that the approximations may not hold true at temperatures far below 100K and that the phase change from gas to liquid introduces significant changes in entropy. The discussion also highlights the importance of accurate values for specific heats and heat of vaporization in calculations.
AbhiNature
Hi All,
I tried to find entropy of liquid nitrogen in various data books, using nitrogen's CAS number, MSDS, but I was able to get the entropy of nitrogen till only 100K, not below that.
Does anyone know what's the entropy of liquid nitrogen or that where can I find it?
Thanks!
Science news on Phys.org
AbhiNature said:
Hi All,
Thanks!
The boiling point of liquid nitrogen at 1 atmosphere was 77°K. Therefore, you have gotten the value of the entropy at pressures above 1 Atmosphere. Regardless, there is a way to estimate the entropy at whatever pressure you are assuming.
I suggest the following approximation to extrapolate the value of the entropy below 100°K. The approximation won't be valid for temperatures far below 100° K, but it should be valid within a limited range of 100°K.
Hypothesize that the specific heat of liquid nitrogen is constant. Furthermore, hypothesize that assume that the liquid nitrogen is being cooled down from 100K at whatever pressure you got that value of entropy from.
The specific heat at constant pressure is defined as C_P where,
C_P=[T∂S/∂T]_P
You can look up C_P for liquid nitrogen in tables. Since C_P is almost constant for liquids, it doesn't matter precisely.
T is the temperature, S is the entropy and P is the pressure.
If you assume that C_P is constant, then you can integrate this equation easily.
ΔS=(C_P)ln(T/100°K)
where ΔS is the change in entropy, T is the new temperature and,
ΔS=S(T)-S(100°K)
Putting the two equations together,
S(T)=S(100°K)+(C_P)ln(T/100°K)
You say you have S(100°K), and you can look up C_P. Thus, you can estimate the entropy at any temperature, i.e., S(T).
Here are some hints.
Note "ln" is the Neparian logarithm, or the "natural logarithm".
The difficult part may be finding the best value of C_P.
For a liquid, there is very little difference between C_P or C_V. The specific heat at constant pressure is almost the same as the specific heat at constant volume for a liquid. So if your table gives you C_V instead of C_P, just use it.
As I said, C_P is almost constant over a large temperature range for a liquid. Similarly, it will be constant over a limited pressure range for a liquid. Therefore, if you can only find C_P at 77°K, use it.
Final hint: There may be something wrong with your value of S(100°K).
Check very carefully whether that CAS number is really for 100°K or 77°K. The standard tables prefer values at 1 Atmosphere. Your question implies a larger value of pressure, which is possible. However, check.
You may have found the entropy of gaseous nitrogen at 100°K. This will not work.
Also note that all this is based on an approximation. One must be wary of approximations. However, this hypothesis is probably the best estimate possible given the limited information in your problem.
Thanks for your reply.
I will like to add few things.
A correction - I have the entropy of nitrogen gas at 100K. Not of liquid nitrogen at 100K.
The equation from which I derived the entropy recommends to use it in the temperature range of 100K-500K. It might be safe to extrapolate till 78K, but below this temperature there will be a sudden drop in entropy(due to change in phase, gas to liquid). Again after phase change there will be slow and smooth reduction in entropy with reduction in temperature.
I wanted to know the entropy of nitrogen at phase change point or below the phase change point(liquid nitrogen) at 1bar pressure.
Well, finding entropy of liquid nitrogen is more difficult than I thought.
As a rough approximition, I took it 120J/moleK.
Following is the reason;
EN2(liquid) = (EBr2(liquid)/EBr2(gas))*EN2(gas)
EN2(liquid) = (152/245)*192 = 120
I guess, this should be close enough.
If you have the entropy of the gas at 100°K, then to find the entropy of the liquid you have to calculate the change in entropy for three separate reversible processes. I hypothesize that the process is occurring at a pressure of 1 Atmosphere.
At 1 Atmosphere, the boiling point of nitrogen is 77°K. The nitrogen gas has to be cooled down to the boiling point, condense into a liquid, and then cooled down to the temperature that you want the entropy at.
1) S(gas, 77°K)=S(gas, 100°K)+C_P[diatomic ideal gas] ln(77°K/100°K)
2) S(liquid, 77°K)=S(gas, 77°K)-ΔH(vaporization, nitrogen)/77°K
3) S(liquid, T)=S(liquid, 77°K)+C_P[liquid nitrogen] ln(T/77°K)
Here, ΔH(vaporization, nitrogen) is the heat of vaporization for nitrogen, C_P[diatomic ideal gas] is the specific heat at constant pressure for a diatomic gas, C_P[liquid nitrogen] is the specific heat at constant pressure for liquid nitrogen and T is the temperature of interest. The heat of fusion is also called the enthalpy of fusion.
The three steps above should be valid down to the freezing point of nitrogen. Extending this method to temperatures just below the freezing point should be obvious. At temperatures far below the freezing point, the specific heat will stop being constant with temperature. However,
You will need to look up C_P[liquid nitrogen] and ΔH(vaporization, nitrogen) in a table. C_P[diatomic ideal gas] is the same for all diatomic ideal gases. Nitrogen is a diatomic gas. The units have to be consistent. Therefore, you may have to manipulate the values that you look up on a table.
C_P[liquid nitrogen]≈C_V[liquid nitrogen]
[/QUOTE]
You already have S(gas, 100°K). I couldn't find it in the CRC manual, but you have it. Here is the rest of the information that you will need.
Handbook of Chemistry and Physics, 84th Edition, 2003-2004
David R. Linde, Editor in Chief
Properties of Cryogenic Liquids
Page 6-142
T(Nitrogen vaporization)=77.35 °K
ΔH(vaporization, nitrogen)=25.3 J/g
C_P[Nitrogen gas]=1.34 J/(g °K)
C_P[Liquid nitrogen]=2.042 J/(g °K)
These values, together with the formulas above, determine the entropy density in units of J/(g °K) at any temperature T in °K.
I suspect not. There is no physical reason that the entropy should scale in this region.
I gave another post where I detail a better way to calculate the entropy. The main physical reason I used that method is because entropy is a perfect differential for reversible processes. Therefore, one can break up the entropy into three components. The proportionality that you just used is based on - what?-
The method that I suggested requires you looking up the heat of vaporization of nitrogen and the specific heat of liquid nitrogen. I think that would work far better than your proportionality.
Thanks Darwin and Q_Goest!
The information is there in the NIST site that Q_Goest mentioned.
Entropy of liquid nitrogen at 1bar pressure and 77.244K is 79.313J/moleK.
I was quite off the mark.
I will like to close this thread now.
Thank you!
  • · Replies 109 ·
10K
  • · Replies 22 ·
