Why Does Ice Cream Soften Differently Than Bread in the Microwave?
  • Context: High School
  • Thread starter Thread starter i0n
    Interesting
The discussion revolves around the differing behaviors of ice cream and bread when heated in a microwave, focusing on why ice cream tends to soften more in the center while bread softens on the outside. Participants explore the underlying mechanisms of microwave heating and the properties of the materials involved.
  • One participant observes that ice cream softens in the center while bread softens on the outside when microwaved.
  • Another participant suggests the opposite, claiming that bread softens on the inside due to moisture content, while ice cream melts more on the outside.
  • A participant mentions that microwaves primarily heat water, which is present in both foods, but the distribution of moisture affects heating patterns.
  • Another contributor notes that in addition to water, sugars and fats also heat up in the microwave, which may influence the softening of ice cream.
  • A participant speculates that the manufacturing process of ice cream could result in varying concentrations of sugars and fats, affecting how it heats.
  • One participant introduces the concept of microwave adsorption cross sections, suggesting that different materials absorb microwave energy at different rates, affecting how they heat internally versus externally.
  • Another participant raises a question about the method of heating ice cream, asking whether it is heated in its container or on a dish, which could influence the heating process.
Participants express differing views on the heating behavior of ice cream and bread, with no consensus reached on the mechanisms at play. Multiple competing explanations are presented without resolution.
Participants reference various factors such as moisture content, microwave energy absorption, and the physical state of the materials, but these points remain speculative and are not fully resolved.
Readers interested in food science, microwave technology, or the physics of heat transfer may find this discussion relevant.
i0n
I put icecream in my microwave for about 20 seconds. When i take it out i notice that it's softest in the centre. However, when i defrost a loaf of bread it's always softest on the outside and still cold in the centre. Why is this, and if you don't believe me try it!
Science news on Phys.org
I reckon you got those backwards. Bread gets soft on the inside and ice cream on the outside. The first thing to understand is that the main thing microwaves heat up is water. Water is pretty much in every food, so the more there is the faster it will heat up. The waves can easily penetrate the outside of the bread, and on the inside, where it's more MOIST, it causes those molecules to heat up. On the other hand, ice cream is pretty moist all around, so it doesn't penetrate to the center, and the outside gets melted more.
How a microwave works: http://home.howstuffworks.com/microwave.htm
no man, I know how a microwave works but this has been puzzling me for ages and I experience it every time i heat up icecream. It's so weird.
additional:
Besides water, it also heats sugars and fats.
Also Ion, there is a way that you can check the speed of light using your microwave. Search GOOGLE for "Microwave+speed of light"
How old is the microwave?
The microwave is roughly a year old and is 900watts. I think due to the manufacturing process, there is more sugars or fats in the centre of the icecream tub, which causes the strange phenomena!
I would have to guess that every material has some sort of microwave adsorption cross section. This cross section would not depend only on molecular properties but not necessarily bulk density.
In a material with a low (or small) microwave cross section you will see deeper penetration, this would be indicated by deeper interior warming, and perhaps slower over all warming, if not all of the microwave energy is adsorbed (think plastic plate).
Material with a high (or large) microwave cross section will adsorb the microwave energy much quicker after it enters the material, here you may well see a skin depth, an outer layer that gets warm quickly while the interior remains cool.
There is a separate phenomena at work in a microwave. Since the outer layer of the material is continuously exposed to room temperature air, it will generally warm up slower then the interior of the material, which can only conduct energy to other interior points. So in general the interior heats up faster in a microwave then the exterior.
Why do you heat up icecream?
Melted icecream tastes way better than frozen ice cream!
Being at room temp releases the flavors! o/
i0n, you have got us curious.
please take a multimeter ("voltmeter" that can measure ohms resistance)
and see if there is signif difference between surface resistance of
loaf of bread straight from freezer, and container of icecream
maybe the loaf of bread is covered with a layer of frost
that is conductive
and the frost melts and dampens the crust
maybe the frost on the bread is more crystalline ice (bigger crystals)
and the icecream has only small crystals because emulsified and thoroughly blended to smoothness
It beats me. I cannot think why the core of the bread will not heat while the icecream does
do you heat the icecream in its cardboard container or out in the open on a dish
  • · Replies 59 ·
12K
  • · Replies 16 ·
  • · Replies 20 ·
24K
  • · Replies 23 ·
16K
