Re-Expressing a Quotient of Polynomials
The discussion revolves around the expression of a quotient of polynomials, specifically focusing on the relationship between the polynomials P(x) and Q(x), where Q(x) is expressed in factored form. Participants are trying to understand the notation and reasoning behind the terms P(aᵢ) and Q'(aᵢ) in the context of polynomial division.
  • The original poster attempts to understand the origin of the terms P(aᵢ) and Q'(aᵢ) in the polynomial quotient expression. Some participants suggest exploring simple examples to clarify the notation and its implications. Others question the necessity of the derivative in the context of the problem.
Participants are actively engaging with the problem, with some providing examples to illustrate their points. There is a mix of confusion and exploration regarding the role of derivatives and the specific notation used in the expression. While some guidance has been offered, there is no explicit consensus on the interpretation of the terms involved.
There is mention of the age of the source material, which raises questions about the clarity of the notation used. Participants are also considering the implications of working from first principles versus relying on established notation.
sponsoredwalk
This is a basic question but I don't think I've ever seen anything like it before.
If [tex]Q(x) \ = \ b_0(x \ - \ a_1)(x \ - \ a_2)\cdot \ . \ . \ . \ \cdot (x \ - \ a_s)[/tex]
then
[tex]\frac{P(x)}{Q(x)} \ = \ R(x) \ + \ \sum_{i=1}^s \frac{P(a_i)}{(x \ - \ a_i)Q'(a_i)}[/tex]I just don't understand where the P(aᵢ) & Q'(aᵢ) come from, maybe it's just notation masking something obvious but idk... I can't really make sense of it.
If this doesn't make sense it's from page 12 of this.
then
This should really be in the Calculus and beyond forums (due to the fact that it involves a derivative). Anyways, what have you tried? If you are completely stuck, what do you get when you multiply your equation by [itex](x-a_n)[/itex] and take the limit as [itex]x \to a_n[/itex]?
You might start by looking at a very simple example. Suppose [itex]Q(x)= (x- 1)(x- 2)= x^2- 3x+ 2[/itex] and [itex]P(x)= x^3[/itex]. Then
[tex]\frac{P(x)}{Q(x)}= x+ 3+\frac{7x- 1}{(x- 1)(x- 2)}[/tex]
Q'(x), the derivative of Q(x), is 2x- 3.
Now, [itex]a_1= 1[/itex], [itex]P(a_1)= P(1)= 1^3= 1[/itex] and [itex]Q'(a_1)= Q'(1)= 2(1)- 3= -1[/itex] while [itex]a_2= 2[/itex], [itex]P(a_2)= P(2)= 2^3= 8[/itex] and [itex]Q'(a_2)= Q'(2)= 2(2)- 2= 1[/itex]. So
[tex]\sum \frac{P(a_i)}{(x- a_i)Q'(a_i)}= \frac{1}{(x- 1)(-1)}+ \frac{8}{(x- 2)(1)}= \frac{-(x-2)}{(x-1)(x-2)}+ \frac{8(x- 1)}{(x-1)(x-2)}[/tex]
[tex]= \frac{-x+ 2+ 8x- 8}{(x-1)(x- 2)}= \frac{7x- 6}{(x-1)(x-2)}[/tex]
just as it should.
Aargh I should have just ignored the P(aᵢ) & Q'(aᵢ) inventing fantasy reasons why the Q' term is in the denominator etc... & worked from first principles!
Okay so working from
[tex]\frac{P(x)}{Q(x)} \ = \ R(x) \ + \ \sum_{i=1}^n \frac{d_i}{(x \ - \ a_i)}[/tex]
[tex](x \ - \ a_j) \cdot \ \frac{P(x)}{Q(x)} \ = \ (x \ - \ a_j) \cdot \ R(x) \ + \ (x \ - \ a_j) \cdot \ \sum_{i=1}^n \frac{d_i}{(x \ - \ a_i)}[/tex]
[tex]\frac{P(x)}{Q'(x)} \ = \ (x \ - \ a_j) \cdot \ R(x) \ + \ (x \ - \ a_j) \cdot \ \sum_{i=1,i\neq j}^n \frac{d_i}{(x \ - \ a_i)} \ + d_j[/tex]
(Where Q'(x) = Q(x)/(x - aj) )
[tex]\lim_{x \rightarrow a_j} \ \frac{P(x)}{Q'(x)} \ = \ \lim_{x \rightarrow a_j} (x \ - \ a_j) \cdot \ R(x) \ + \ \lim_{x \rightarrow a_j} \ (x \ - \ a_j) \cdot \ \sum_{i=1,i\neq j}^n \frac{d_i}{(x \ - \ a_i)} \ + \lim_{x \rightarrow a_j} \ d_j[/tex]
[tex]\frac{P(a_j)}{Q'(a_j)} \ = \ 0 \cdot \ R(a) \ + \ 0 \cdot \ \sum_{i=1,i\neq j}^n \frac{d_i}{(a_j \ - \ a_i)} \ + \ d_j[/tex]
[tex]\frac{P(a_j)}{Q'(a_j)} \ = \ d_j[/tex]
So I don't see what the derivative has to do with anything :confused: The book is nearly a hundred years old so I didn't really think it was fair to assume Q' means the derivative unless he specified this, which he does when he actually uses derivatives a page or so later, so thanks a lot!
  • · Replies 35 ·
  • · Replies 0 ·
