2 objects 1 up and 1 down thrown
  • Thread starter Thread starter runner1738
The problem involves two objects: one thrown downward from a height and the other propelled upward from ground level. The context is kinematics, specifically analyzing the motion of the two objects under the influence of gravity.
  • Participants discuss using kinematic equations to equal the distances traveled by both objects to find the point where they meet. There are attempts to set up equations based on initial velocities and acceleration due to gravity.
Some participants have provided guidance on the correct setup of the equations, including noting the direction of velocity for the object thrown downward. There is ongoing exploration of the calculations, with participants sharing their results and questioning the units of their answers.
There are mentions of confusion regarding the signs of velocities and the need for clarity on the units of the final answer. Participants are also grappling with the implications of their calculations and the assumptions made in the problem setup.
runner1738
An object is thrown downward with an initial speed of 9 m/s from a height of 40 m above the ground. At the same instant, a second object is propelled vertically from ground level with a speed of 14 m.s. The acceleration of gravity is 9.8 m/s^2. At what height above the ground will the two objects pass each other? Abswer in units of m?
christinono said:
Use the following kinematics formula and equal the distances they travel. Then, solve for time.
[tex]d = V_it+ \frac{1}{2}at^2[/tex]
Same idea as this one. Equal the distances.
i guess i just can't do math in general casue i got 9t + 1/2(9.8)t^2=14t+1/2(-9.8)t^2
9.8t^2-5t=0 , that i got .5102040816 * what though?
Remember, the one being thrown down has a NEGATIVE velocity (negative direction).
ok gotcha i think, thanks for all the help
ok this time around i got 2.346938976 from -9t+1/2(9.8)t^2=14t+1/2(-9.8)t^2, but the answer is supposed to be in m? and i have time
From the time, you can find the distance. Just use the formula:
[tex]d=V_it + \frac{1}{2}at^2[/tex]
  • · Replies 38 ·
11K
  • · Replies 25 ·
