Thread Closed
Anti-Ballistic Systems
Share Thread Thread Tools
Feb6-05, 10:31 AM   #1
A few of the key problems of making the system efficient is properly targeting the incoming missile not to mention the multiple decoys and warheads.
Can this problem be solved by fixing a powerful explosive, possibly a very small nuclear bomb on the anti-ballistic missile such that it explodes whenever the defense missile hits the incoming missile or when it misses its mark killing whatever possible warheads or decoys that are deployed?
What other solutions can be there to this problem?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Feb6-05, 12:04 PM   #2
Admin
Quote by sid_galt
. . . whenever the defense missile hits the incoming missile or when it misses its mark killing whatever possible warheads or decoys that are deployed?
That is the $64 billion question.
There are two phases to ABS problem -
1) Detection
2) Interception
MIRV's complicate the solution.
Basically, for every defense, there is an effective counter-measure that will defeat that defense.
Feb9-05, 03:55 PM   #3
Quote by sid_galt
Ahh... just what we want. A nuclear bomb spreading waste materials all over a large land area (and destroying electrical devised for miles with an electromagnetic pulse) all because our tracking system misidentifies a speeding Leerjet in the wrong airspace as a missile.
Feb10-05, 03:22 AM   #4
Quote by ohwilleke
I am talking about a very small nuclear bomb (which won't generate much electromagnetic pulse either) which has a much lesser yield than even the Hiroshima bomb but just sufficient to destroy the incoming missiles, its decoys and its multiple warheads. Instead of nuclear bomb one might use any other bomb one but I am not sure any chemical bomb would be sufficiently powerful to be useful.
I don't think it's so easy to misidentify a Leerjet as a missile. A missile has a parabolic trajectory while a Leerjet doesn't.
Feb10-05, 12:38 PM   #5
Recognitions:
Gold Membership Gold Member
Quote by sid_galt
I am talking about a very small nuclear bomb which has a much lesser yield than even the Hiroshima bomb
Well, that's a relief!
Quote by sid_galt
A stone has a parabolic trajectory, a cannonball has a parabolic trajectory, but a missile? Let's think about this one.
Feb10-05, 02:02 PM   #6
Mentor
Quote by brewnog
A nuclear missile spends most of its flight in a ballistic/parabolic trajectory (that's why they call them "ballistic missiles"). But that's not even the main reason why such an error would be improbable - the flight profiles are otherwise as different as flight profiles could be:
-Learjet: 30,000 feet, level, 500 kts.
-ICBM (boost phase): 30,000 feet, climbing at 70 degrees, 4,000 kts (guess)
-ICBM (re-entry phase): 30,000 feet, falling at 80 degrees, 8,000 kts (guess)
Avoiding hitting a learjet is as simple as programming the radar to not even lock onto a target traveling at less than 1000 kts. Currently, the ABM treaty prevents us from tracking objects in space and so AEGIS has the opposite constraint put on it: software restricts it to track only those objects below a certain altitude and speed.
For the OP, using a large explosion to bring down multiple warheads would be problematic: they may not be close enough to each other to bring them down with one shot, even with a nuke. What's more, a nuclear warhead is traveling so fast, it has to be flying toward any explosion (even a nuclear one if you want the blast, not the em radiation you want to destroy the missile) meant to destroy it. If the warhead is moving at say, 8,000 kts and the explosion propagates at 2,000, essentially all the explosion is there for is to create a cloud of debris for the missile to fly through.
Feb10-05, 04:45 PM   #7
Quote by sid_galt
Patriot Missile batteries have mistaken F-16s for missiles causing friendly fire casualties which is what gave me the idea. A cruise missile wouldn't necessarily follow a parabolic trajectory and could easily be designed to carry a nuclear warhead.
Feb10-05, 04:48 PM   #8
Quote by russ_watters
The U.S. has withdrawn from the ABM treaty per the instructions of the current administration.
See e.g. http://archives.cnn.com/2001/ALLPOLI.../rec.bush.abm/
Feb10-05, 04:55 PM   #9
Recognitions:
Quote by ohwilleke
Cruise missiles follow paths similar to N.O.E. flying aircraft. The difference comes in at the end of the flight, near the intended target in the "pop-up" phase. They already do carry tactical nukes.
Mar16-05, 01:59 PM   #10
Community 2012
Recognitions:
Quote by ohwilleke
F-16's are incredibly fast aircraft. I believe they have a top speed of M2.5. The SCUD-B variation in Iraq (i believe its the B) traveled 300km and i believe i read a report saying coalition forces had 20 minutes from time of launch to impact. Im not sure what the exact math is but its distance traveled was probably 800km or so in around 20 minutes which comes out to 2400km/ hour which is well in the speed-specifications for an F16. ICBM's though make a 10000km trip in about an hour, something only experimental NASA aircraft can really do so your really going ot be hard pressed to find an aircraft going into the upper atmosphere at thousands of miles per hour and mistakenly blow it out of the sky.
As to whoever mentioned the nuclear-tipped defense, the first 'allies' ballsitic missile defense system (joint US-UK venture i believe) was actual nuclear weapons tipped missiles that would come within a few miles of the incoming missiles and detonate
Mar16-05, 02:00 PM   #11
Community 2012
Recognitions:
Quote by FredGarvin
And of course, who teh heck is going to fire a cruise missile at the mainland USA? Unless you develop stealth technology, your not going to get close enough to try it.
Mar16-05, 06:56 PM   #12
Canada?
Mar16-05, 09:53 PM   #13
Community 2012
Recognitions:
Thats why ive always proposed invading canada and mexico and cuba... cant be too careful with these people bieng so close :P
Apr23-05, 12:07 AM   #14
I believe the US is a signatory to treaties outlawing nuclear explosions in the atmosphere and in space.
Apr23-05, 12:36 AM   #15
Community 2012
Recognitions:
Wooo resurrected threads :D
The US and British plans to detonate nuclear weapons in the atmosphere to stop incoming missiles was in the early early days of ICBM's and before that treaty was signed.
Apr27-05, 11:33 PM   #16
sid galt
I wrote a paper in 1979 presenting a case for a terrestial non-nuclear defense system.This system was designed to utilize existing technology to accomplish several goals.
The first was a system that could not be used against the indigenous population and one that did not present a terrosist target.
The second requirement was to have characteristics of either outright destruction of the target or to knock it away from its' intended target.
The third was a system that could be utilized for the benefit of the community at large in the event of natural disasters.
the fourth was that the system could be sustained using indegeaneous fuels or known as being omnivorous (regarding fuels) alcohol,diesel,jet fuel, peanut oil etc. etc.
the fifth was this defense system would or could be privately owned and operated with and by private citizens from the surrounding communities
the sixth was that system during non emergeny operations would be 'solar powered' with the definition of fermentation as being one form of renewable solar energy.
The system I came up with utilized railroad diesel locomotives with four to six tank cars and four to eight flat bed cars housing 'knetic energy' weapons or otherwise kown as 'rail guns'. There would be several cars for high density electrical energy storage or (super capicators) capable of storing several gigawatts.
Assuming the area to be protected is Los Angeles which is the home for several million people and has perhaps the largest city limits also has an intricate rail systen with rail sidings ideal for permanetly located defense systems.
the city limits for hypotetheticals exceeds one hundred square miles and assuming a defense weapon at every node of a ten by ten matrix the volume and density of the projectiles poured into to the reentry window that mirv's or other offensive weapons 'have' to go through could easily fulfill the above mentioned criteria.
I spent a lot of time trying to implement the idea to no avail, though. Anyway that would be one way to accomplish your goal.
Refugee from the Nuclear Industry.
frank MR. P
Apr28-05, 10:39 AM   #17
Mr. P has anyone , to your knowlege , ever tried to store energy from lightning?
what would we need for such a system?
Very very large capicitors?
how large a cap would we need , theoretically ?
Thread Closed
Thread Tools
Similar Threads for: Anti-Ballistic Systems
Thread Forum Replies
something i thought of involving hamiltonian systems and gradient systems Differential Equations 0
Signals and Systems: Response of LTI systems to Complex Exponentials Electrical Engineering 1
Senator Sam Brownback of Kansas running on anti-evo, anti-stemcell '08 Prez. campain Current Events 30
anti-graviton = anti-gravity? High Energy, Nuclear, Particle Physics 7
Classical Systems With Variable Mass And Other Geometric Systems: Advanced Physics Learning Materials 8
