Finding a One-Way Membrane Solution
  • Thread starter Thread starter strokebow
    Membrane
The discussion centers around the search for a one-way membrane that allows water to pass through in one direction while preventing backflow. Participants explore potential materials and solutions, including comparisons to existing products and alternative mechanisms.
  • Exploratory, Technical explanation, Debate/contested
  • One participant requests a membrane that permits fast one-way water flow, distinguishing it from typical damp proof membranes.
  • Another participant suggests Gore-Tex as a potential solution, noting its ability to allow water vapor through one-way.
  • The original poster clarifies that they are looking for a solution that accommodates bulk water flow rather than vapor.
  • A different participant questions whether a membrane is necessary, proposing the use of check valves as an alternative that allows flow in one direction.
Participants have differing views on the feasibility of using a membrane versus a check valve, indicating that the discussion remains unresolved regarding the best approach to achieve the desired one-way water flow.
The discussion does not clarify specific requirements for the membrane or check valve, such as material properties or application contexts, which may affect the proposed solutions.
strokebow
Hi guys,
I am in need of a 'one-sided' membrane.
Basically, something like a bad damp proofing membrane. Allow me to explain:
A membrane which will allow water to pass through one-way (at a fast rate - this is where it differs from the damp proof membrane you can buy in the diy shop). But not allow water to pass back through the other side.
Any ideas? Info? Advice?
cheers!
thanks for your reply lisab.
However, I am thinking more of a water flow. Gore-Tex and products like it will let vapours pass back through but I want a bulk flow.
Any ideas?
Does it have to be a membrane? There are many types/sizes of check valve that only allow flow in one direction.
9K
11K
