What Are the Key Differences Between Graduate and Undergraduate Research?
The discussion explores the differences between undergraduate and graduate research, focusing on aspects such as independence, guidance, project originality, and the potential for overlapping theses in related fields like applied physics and robotics engineering.
  • Some participants suggest that undergraduate research often involves working on projects conceived by professors, rather than developing original ideas independently.
  • Others argue that while undergraduates may contribute to existing projects, they can still engage in original research, though this is considered rare.
  • It is noted that undergraduate research typically involves more guidance from professors, while graduate research requires greater independence and responsibility.
  • One participant mentions that the time spent on research as a graduate student is more focused on implementation and analysis rather than idea generation.
  • Concerns are raised about the feasibility of completing a single thesis that satisfies both applied physics and robotics engineering, with some suggesting that this depends on advisor agreement.
Participants express differing views on the nature of undergraduate research, particularly regarding its originality and independence compared to graduate research. The discussion remains unresolved on the specifics of thesis overlap between the two majors.
Participants indicate that the level of guidance and responsibility varies significantly between undergraduate and graduate research, but the exact nature of these differences may depend on individual experiences and specific academic programs.
camjohn
I understand that undergraduate research is big at UCSC and that it is required for both of my prospective majors (physics and robotics engineering). What I'm trying to figure out is the specific differences between undergraduate and graduate research. I would guess that undergraduate reseach is basically just doing busy work for professors with their own potential theses and project ideas in my mind, but I've been told that's wrong; undergraduate students actually explore their own projects in my mind. My questions are: how is this different from postdoctoral work? How much time does it take? Is it essentially equivalent to taking another class? Could I potentially create one thesis for both applied physics and robotics engineering? (Given that they're related fields)
Thanks
Undergraduate research can be something original that isn't just part of your professor's research, but it's usually not based on an original idea you had. Most students simply don't know enough about the field to come up with an original idea and then work through it with a minimum of support. That's more like graduate research. Undergrad research is strongly guided by your professor, from picking out the topic to assigning research papers to read to telling you what to do every step of the way if you need it. Postdoctoral work, which comes after graduate school, is often completely independent.
In my experience, the undergrad students tend to pursue the little side-projects that profs/grad students thought of. One of the projects I've done was something that had already been done, but not by that particular research group. They wanted someone to read up on it and test some things so they could implement it in their research.
I'm still an undergrad myself, but it seems that the amount of time you spend coming up with research ideas as a grad student is nothing when compared to the time you spend implementing, debugging, testing, and writing about them. I'm guessing it's more important to get experience with all that stuff.
I would say the biggest difference between undergrad and graduate research is that you will be held responsible for graduate research, while if you don't make any progress but give a full effort as an undergrad, that's fine.
You will also get a lot more hand holding as an undergrad. This is good, because you will still have a lot to learn. As a grad student (and more as a post doc) you're just thrown in the deep end of the pool.
Also, researching an original idea takes a long, long, time. It is possible to do something original as an undergrad, but it's rare.
And performing work for professors isn't "busy work". It's research. Seriously, research is like 5% dreaming up ideas and 95% reading papers, analyzing data, writing code, setting up experiments, and the like.
OK this is basically what I thought it was. Could I potentially do one thesis for both majors? Research that would overlap both applied physics and robotics engineering?
You can do whatever you get your advisors to agree to. Not trying to be glib, but that's how things work. I don't think it would be a problem to find a research problem that would satisfy both advisors, but you will have to ask them.
  • · Replies 53 ·
10K
  • · Replies 23 ·
