Derivative Mapping in V: Understanding Rank, Nullity, Nullspace, and Range of D
  • Context: Graduate
  • Thread starter Thread starter eckiller
The discussion focuses on the derivative mapping D applied to kth order polynomials with real coefficients, confirming that D maps V into V. The rank of D is established as k, while the nullity is 1, indicating that only constant polynomials and the zero polynomial have zero derivatives. The nullspace N(T) consists of constant polynomials, and the range R(T) includes polynomials of degree at most k-1. The conversation emphasizes the importance of rigorous proof in establishing these properties.
  • Understanding of polynomial functions and their derivatives
  • Familiarity with linear transformations and their properties
  • Knowledge of rank and nullity in linear algebra
  • Concept of nullspace and range in vector spaces
  • Study the properties of linear transformations in vector spaces
  • Learn about the Fundamental Theorem of Algebra and its implications for polynomial degrees
  • Explore rigorous proof techniques in linear algebra
  • Investigate the relationship between rank, nullity, and dimension in vector spaces
Mathematicians, students of linear algebra, and anyone interested in the properties of polynomial functions and their derivatives.
eckiller
Q. Consider the case with V being the kth order polynomials with real coefficients. Let the derivative mapping D be the transformation which assigns to each polynomial function its derivative. Show that D maps V into V. What is the rank, nullity, nullspace, and range of D?
This is what I did:
Let p = a_0 + a_1 x + a_2 x^2 +...+ a_k x^k in V.
D(p) = a_1 + 2 a_2 x + ... + k a_k x^(k-1).
So D(p) in V since it is a polynomial of at most k.
Now the thing with the rank and nullity, is there suppose to be a rigorous way to show these? The only way I know how to find them is by "eyeballing" the space.
I note that only constants and the zero polynomial have zero derivatives, hence N(T) = { a_0 | a_0 in Reals }.
And the range R(T) = {p(x) | p(x) = a_1 + 2 a_2 x + k a_k x^(k-1) }
Rank(T) = k
Nullity(T) = 1
Dim(V) = k + 1
Thanks for checking my work.
eckiller said:
This is what I did:
Of at most what? Degree? That would be wrong, since they are of degree at most k-1. You're right, D(p) is in V, and I suppose you've shown it, but it's not technically correct to say, "it is a polynomial of at most (degree) k", rather, you should say that it is a polynomial of degree no greater than k, thus it is in V.
You want to find the polynomials whose derivative is zero. Can't you rigourously prove that only constant polynomials have derivative zero? Pick an arbitrary polynomial in V, take it's derivative, recognize that it is a sum of linearly independent vectors {1, x, x², x³, ... x^(k-1)} and so for it to be zero, the coefficients must be zero. Conclude that if all those coefficients must be zero, then the original polynomial must be constant.
Again, you can easily prove this. Take an arbitrary element of V and show that T maps it into the space that you've stated above. Also show that any element in that space (notice that it is the space of polynomials of degree at most k-1) is the image of some element of V. This shows that R(T) is a subset of the k-1 polynomials, and that the k-1 polynomials is a subset of R(T), showing that the two sets are equal as you've asserted.
You've done everything right, just make sure you take the time to prove it.
Great...thanks very much. That helped clear some things up.
  • · Replies 28 ·
