| Thread Closed |
Definite Integral of ln*algebraic function |
Share Thread | Thread Tools |
| Feb7-05, 09:25 AM | #1 |
Hello...
I got a simple looking integral to solve but unfortunately couldn't do it [tex]I = \int_{0}^{1}\frac{x^2lnx}{\sqrt{1-x^2}}dx[/tex] Any suggestions? Thanks and cheers Vivek |
| Feb7-05, 09:30 AM | #2 |
Here's what I did:
Let [itex]J = \int \frac{x^2lnx}{\sqrt{1-x^2}}dx[/itex]. Integrating J by parts, [tex]J = lnx\int \frac{x^2}{\sqrt{1-x^2}}dx - \int \int \frac{x^2}{\sqrt{1-x^2}}dx \frac{dx}{x}[/tex] [tex]\int \frac{x^2}{\sqrt{1-x^2}}dx = -\int \frac{1-x^2}{\sqrt{1-x^2}}dx + \int \frac{1}{\sqrt{1-x^2}}dx = \frac{1}{2}(\sin^{-1}x-x\sqrt{1-x^2})[/tex] So [tex]J = lnx(\frac{1}{2}(sin^{-1}x-x\sqrt{1-x^2}+) - \frac{1}{2}\int \frac{\sin^{-1}x-x\sqrt{1-x^2}}{x}dx[/tex] One of the integrals to be further computed is [tex]\int \frac{\sin^{-1}x}{x}dx[/tex]. This leads us nowhere I can't think of any property of definite integrals (thanks to the ln function) which I can apply here. I know that this is an improper integral as such so I'll have to take limits after I've evaluated the corresponding indefinite integral somehow. Please help..... Mathematica gives the answer as [tex]\frac{-\pi}{8}(-1+ln4)[/tex] but I had to do this by hand... Thanks and cheers Vivek |
| Feb7-05, 10:56 AM | #3 |
in your second line of equations with the double integral, are you sure you can bring that 1/x inside? I didnt think you could do that.
| Feb7-05, 11:37 AM | #4 |
That's NOT integration by parts! and
[tex]\int \int dx \frac{dx}{x}[/tex] makes no sense at all- you can't do a double integral over the SAME variable! |
| Feb7-05, 11:48 AM | #5 |
Recognitions:
I've thought of a way you can evaluate the indef. integral. I haven't written out the working, but I'll give you the gist. Be warned, it's tedious. But fairly elementary.
[tex]I = \int \frac{x}{\sqrt{1-x^2}}(x\ln x) dx[/tex] Integration by parts, udv + vdu = uv Let [tex]\frac{x}{\sqrt{1-x^2}}[/tex] be dv, and [tex](x\ln x)[/tex] be u Then v will be [tex]-(1 - x^2)^{\frac{1}{2}}[/tex] And du will be [tex](1 + \ln x)[/tex] Now we need to integrate vdu wrt x. vdu can be expressed as the sum of [tex]-(1 - x^2)^{\frac{1}{2}}dx[/tex] and [tex]-(1 - x^2)^{\frac{1}{2}}(\ln x)dx[/tex] The first term can be easily evaluated by making the substitution [itex]x = \sin \theta[/itex] Let's integrate the second term. Make the same substitution [itex]x = sin \theta[/itex]. The second term becomes [tex]-\cos^2(\theta) \ln(|\sin \theta|) d \theta[/tex] Integrate that by parts. Use [tex]\cos^2(\theta) = dv[/tex] and [tex] \ln(|\sin \theta|) = u[/tex] Then vdu becomes [tex]-\frac{1}{2} \left( \cot \theta \cos(2\theta) + \cot \theta \right)d\theta[/tex] which can be simplified to [tex](\frac{1}{2}\sin 2\theta - \cot \theta)d \theta[/tex] Integrating [tex]\sin (2\theta)d\theta[/tex] is trivial. Integrating [tex]\cot \theta[/tex] is easy because, being the ratio of cosine to sine, it is of the form [tex]f'(x)g(f(x))[/tex] giving the integral as [tex]\ln|\sin\theta|[/tex] Put everything together and you'll have your answer as an indefinite integral. Evaluate for the bounds for the final numerical answer. |
| Feb7-05, 11:51 AM | #6 |
Try the substitution[tex] x=\sin u [/tex] under which the limits of integration become [tex] u_{1}=0;u_{2}=\frac{\pi}{2} [/tex] The integral becomes [tex] J=\int_{0}^{\frac{+\pi}{2}} \sin^{2}u \ \ln\sin u \ du [/tex] Mathematica on the wolfram's site gives the antiderivative: (see attachement) which is pretty nasty.Not to mention the fact that applying the FTC will produce a terrible headache. Daniel. |
| Feb8-05, 02:37 AM | #7 |
[tex]\int udv = uv - \int vdu[/tex] In my case v is a function defined by an integral (say [itex]v=\int f(x)dx[/itex]). So the above integral can be rewritten in terms of f(x) as: [tex]\int udv = u(\int f(x)dx) - \int (\int f(x)dx)du[/tex] It is obviously understood that the two integrals cannot be commuted. So I thought you would understand and hence did not place the parantheses. Sorry for the confusion though. Also when I entered the original integral in Mathematica with the limits, I got the answer mentioned in my second post. I wonder how you got a different answer dextercioby. Curious3141, I'm going to try out the approach you've suggested in a while. Thanks for your help mates I did make the obvious substitution but couldn't take it further by hand. (This was a question on a math test ).Cheers Vivek |
| Feb8-05, 02:48 AM | #8 |
To add to my last post (to clear your doubts Healey01 and Hallsofivy),
[itex]u = lnx[/itex] [itex]dv = \frac{x^2}{\sqrt{1-x^2}}[/itex] or equivalently [itex]v = \int \frac{x^2}{\sqrt{1-x^2}}dx[/itex] And by the way hallsofivy, velocity = [itex]v = \frac{dx}{dt}[/tex] acceleration = [itex]a = \frac{dv}{dt} = \frac{d^2x}{dt^2}[/itex] position = [itex]x = \int v dt = \int (\int a dt)dt[/itex] |
| Feb8-05, 02:58 AM | #9 |
let your [itex] u = \frac{x^2}{\sqrt{1-x^2}}[/itex], and [itex] dv = lnx dx [/itex] and do it by part....
| Feb8-05, 07:28 AM | #10 |
Recognitions:
Vivek, I think I may have made a bad error in my computation in the later steps. I tried it again, and I get an integrand of [tex]\theta \cot \theta[/tex] which I cannot integrate easily. It still comes back to [tex]\int \ln|\sin \theta| d\theta[/tex] which I don't think has an elementary integral.
Sorry I misled you. :( I think this isn't an elementary integral at all. |
| Feb8-05, 11:07 AM | #11 |
cheers vivek |
| Feb8-05, 11:10 AM | #12 |
why don't you use my method posted above.....
| Feb8-05, 11:26 AM | #13 |
I don't know,because it lead...nowhere...?
Da |
| Mar7-05, 11:06 PM | #14 |
The definite integral to be done is given by
[latex] I = \int^{1}_{0} \frac{x^{2} \ln x}{\sqrt{1-x^{2}}} \ dx \ . [/latex] The primary difficulty of this integral is that it contains a logarithmic function and a square root in the integrand. However, it can be simplified by an integration of parts. [latex] I = - \int^{1}_{0} x \ln x \cdot \frac{-x}{\sqrt{1-x^{2}}} \ dx = - \int^{1}_{0} x \ln x \cdot \frac{d}{dx}\sqrt{1-x^{2}} \ dx [/latex] [latex] = - \left[ x \ln x \sqrt{1-x^{2}} \right]^{1}_{0} + \int^{1}_{0} \left( 1 + \ln x \right) \sqrt{1-x^{2}} \ dx \ . [/latex] It can be easily determined that the first term on the right of the above equation is zero. Hence, we have [latex] I = \int^{1}_{0} \sqrt{1-x^{2}} \ dx + \int^{1}_{0} \ln x \sqrt{1-x^{2}} \ dx \ . [/latex] The first term on the RHS can be easily solved by using the substitution [latex]x=\sin\theta[/latex], which yields [latex] \int \sqrt{1-x^{2}} \ dx = \frac{1}{2} \left( \sin^{-1}x + x\sqrt{1-x^{2}} \right) \ . [/latex] Thus, we have [latex] I = \frac{1}{2} \left[ \sin^{-1}x + x\sqrt{1-x^{2}} \right]^{1}_{0} + \int^{1}_{0} \ln x \sqrt{1-x^{2}} \ dx = \frac{\pi}{4} + \int^{1}_{0} \ln x \sqrt{1-x^{2}} \ dx \ . [/latex] The second term can be simplified by applying another integration by part. [latex] I = \frac{\pi}{4} + \int^{1}_{0} \ln x \sqrt{1-x^{2}} \ dx \nonumber \\ = \frac{\pi}{4} + \frac{1}{2} \int^{1}_{0} \ln x \cdot \frac{d}{dx}\left( \sin^{-1}x + x\sqrt{1-x^{2}} \right) \ dx \nonumber \\ [/latex] [latex] = \frac{\pi}{4} + \frac{1}{2} \left[\left(\sin^{-1}x + x\sqrt{1-x^{2}}\right)\right]^{1}_{0} - \frac{1}{2} \int^{1}_{0} \frac{1}{x} \left(\sin^{-1}x + x\sqrt{1-x^{2}}\right) \ dx \nonumber \\ = \frac{\pi}{8} - \frac{1}{2} \int^{1}_{0} \frac{\sin^{-1}x}{x} \ dx \ . [/latex] The integral [latex]I[/latex] is now more tractable now that we have got rid of the [latex]\log[/latex] function. The solution can be completed once we evaluate the integral term in the last eqation. Using the substitution [latex]x=\sin t[/latex] and applying an integration by part, [latex] \int^{1}_{0} \frac{\sin^{-1}x}{x} \ dx = \int^{\pi/2}_{0} t \cot t \ dt = \int^{\pi/2}_{0} t \frac{d}{dt}\ln(\sin t) \ dt [/latex] [latex] = \left[t \ln(\sin t)\right]^{\pi/2}_{0} - \int^{\pi/2}_{0} \ln(\sin t) \ dt = - \int^{\pi/2}_{0} \ln(\sin t) \ dt \ . [/latex] Thus, it simplifies to [latex] I = \frac{\pi}{8} + \frac{1}{2} \int^{\pi/2}_{0} \ln(\sin t) \ dt \ . [/latex] Fortunately, the definite integral term in the above equation can be readily evaluated. [latex] \int^{\pi/2}_{0} \ln(\sin t) \ dt = \frac{1}{2} \int^{\pi}_{0} \ln(\sin t) \ dt = \frac{1}{2} \int^{\pi}_{0} \ln\left(2\sin(t/2)\cos(t/2)\right) \ dt [/latex] [latex] = \frac{1}{2} \int^{\pi}_{0} \ln 2 \ dt + \frac{1}{2} \int^{\pi}_{0} \ln(\sin(t/2)) \ dt + \frac{1}{2} \int^{\pi}_{0} \ln(\cos(t/2)) \ dt = \frac{\pi}{2} \ln 2 + 2 \int^{\pi/2}_{0} \ln(\sin t) \ dt [/latex] since [latex] \frac{1}{2} \int^{\pi}_{0} \ln(\sin(t/2)) \ dt = \int^{\pi/2}_{0} \ln(\sin t) \ dt [/latex] and [latex] \frac{1}{2} \int^{\pi}_{0} \ln(\cos(t/2)) \ dt = \int^{\pi/2}_{0} \ln(\cos t) \ dt = \int^{\pi/2}_{0} \ln(\sin t) \ dt \ . [/latex] Therefore, it is obvious that [latex] \int^{\pi/2}_{0} \ln(\sin t) \ dt = -\frac{\pi}{2} \ln 2 [/latex] and that the final answer is [latex] I = \frac{\pi}{8}\left(1-\ln 4\right) \ . [/latex] |
| Mar7-05, 11:34 PM | #15 |
My answer is consistent with Mathematica's so it's alright!
| Mar8-05, 05:54 AM | #16 |
Yes,i didn't claim it could't be done (congratulations!!),just that it was very difficult to find the antiderivative and the apply the FTC...You made use however of the fact that it was a definite integral...
Daniel. |
| Mar8-05, 08:42 AM | #17 |
My first stab three weeks ago at evaluating that integral ended up horribly as I attempted to evaluate [latex]\int^{\pi}_{0} \ln(\sin t) \ dt[/latex] using complex integrals. Functions like [latex]\ln z[/latex] are neither very analytic nor friendly with branch cuts appearing in unwanted places. I gave up after trying for an hour. Then, I had to report to camp for reservist training for the next three weeks...
In the course of doing the complex integrals, I fiddled around with the limits of the integral and discovered some nice symmetries in the definite integral. After that, it was all downhill. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Definite Integral of ln*algebraic function
| Definite Integral | Calculus & Beyond Homework | 1 | ||
| [SOLVED] Definite Integral of Exponential Function | Calculus & Beyond Homework | 4 | ||
| definite integral | Calculus & Beyond Homework | 12 | ||
| definite integral | Calculus & Beyond Homework | 4 | ||
| Definite Integral | Calculus | 1 | ||
