Use Archimede's Spiral For Accelerate An Object.
  • Context: Graduate
  • Thread starter Thread starter lba
    Accelerate Spiral
The discussion explores the feasibility of using an Archimedean spiral to accelerate an object, examining the forces involved and the energy requirements for such a mechanism. It includes theoretical considerations and assumptions about friction and energy consumption.
  • One participant proposes that an Archimedean spiral could accelerate an object by applying a perpendicular force, suggesting that this could allow the spiral to turn without energy input.
  • Another participant counters that since the spiral is not circular, a perpendicular force would still require work, implying energy consumption.
  • A later reply suggests that using multiple centers might reduce energy requirements, but acknowledges that some energy is still necessary.
  • One participant argues that if the object is on a frictionless surface, theoretically, an infinitesimal amount of energy could move the object any distance, regardless of the spiral. However, they note that friction would necessitate energy proportional to the mass and distance moved, regardless of the spiral's presence.
  • It is concluded by one participant that the spiral does not provide any advantage in terms of energy efficiency.
Participants express disagreement regarding the energy implications of using an Archimedean spiral for acceleration, with some suggesting potential energy savings while others argue that energy consumption is unavoidable.
Assumptions about friction, the nature of forces acting on the spiral and object, and the definition of energy efficiency are not fully resolved, leading to varying interpretations of the spiral's utility.
lba
Hi,
Is it possible to help to accelerate an object with an Archimede Spiral ? We can apply a force F perpendiculary to the spiral, like this if we want to turn the spiral in its center we don't need energy. If we want to accelerate an object near the spiral, we apply a force F to the spiral, the spiral apply the same force in the contrary direction. The object accelerate. The spiral can turn without energy if the force F is perpendiculary to the surface (it's possible with an Archimede Spiral). Like the object accelerate, if we want always a contact between the spiral and the object, we need to accelerate the spiral, but this don't require more energy. In this case what is the energy need for accelerate the object ? It is the same without spiral ? Why ?
The spiral is not a circle, so you can't have F perpendicular to it in this arrangement. So there will be some work of F, and energy will be consumed.
You're right but if I use 4 centers like the figure show, it's not possible to turn the spiral without energy ? It's an approximation and a little energy is needed but less I think.
If the object to move is on a frictionless surface, then, theoretically, you need an infinitely small energy and infinite time to move the object to any distance, with or without the spiral. If, however, there is friction, then the force of friction will do work that is proportional to the mass of the object and the distance to move, and you cannot spend less energy than that, again, with or without the spiral.
All in all, the spiral gives you nothing in terms of energy.
  • · Replies 65 ·
  • · Replies 29 ·
  • · Replies 51 ·
