When something gets stuck , whats going on?
  • Context: High School
  • Thread starter Thread starter CuriousBanker
    Stuck
The discussion revolves around the physical principles involved when a knife gets stuck in a wall, particularly focusing on the forces at play, such as gravity, friction, and adhesion. Participants explore the mechanics behind the knife's ability to remain lodged in the wall despite most of its length being suspended in air.
  • One participant questions how a knife can remain stuck in a wall when most of it is not embedded, pondering the role of gravity and other forces.
  • Another participant suggests that friction between the knife and the wall is responsible for keeping the knife in place, comparing it to the suction created when a knife is pulled from a watermelon.
  • A participant confirms that friction is the key force at play, indicating that the frictional force must overcome gravity to prevent the knife from falling.
  • One contributor emphasizes that the adhesion and frictional forces between the knife and the wall material are crucial, noting that different materials would affect the friction experienced.
  • Another participant discusses the weakness of gravitational force between the knife and the wall, suggesting it is negligible compared to frictional forces.
  • A later reply elaborates on the nature of static friction, explaining its mechanism and how it differs from kinetic friction, while introducing concepts like normal force and the coefficient of static friction.
Participants generally agree that friction and adhesion are the primary forces keeping the knife in the wall, but there are varying interpretations of the role of gravity and the specifics of frictional forces. The discussion remains unresolved regarding the exact mechanics and the influence of different materials.
Some participants mention the need for further exploration of the materials involved and the coefficients of friction, indicating that the discussion may depend on specific conditions and definitions that are not fully addressed.
CuriousBanker
When something gets "stuck", what's going on?
Hi,
So I see things in real life, and wonder what is going on physically. I question things that even seem intuitive. I know most of my questions are stupid, but I don't know much about physics. I just bought "conceptual physics" by hewitt on ebay for $7 shipping included. I can't read it yet though because I am studying for my CFA which takes up most of my time.
Anyway, I was at a renaissance fair today, and there was a knife thrower. The tip of the knife strikes the wooden wall, and the knife gets stuck in the wall. But how? I know if the entire knife went in the wall, obviously gravity is pulling it downward and it is resting in the wall. But if only the tip of the knife penetrates the wall, and the other 95% is suspended in the air, how does it not just fall to the floor? Why wouldn't the force of gravity pull the exposed part to the floor? Is there force of gravity between the sides of the knife and the walls touching it overcoming the gravity of the Earth since they are at such a close distance?
have you ever stabbed a knife into a watermelon or something similar and then pulled it out. a suction is created that must be overcome to finally remove it. In a similar fashion, the tip is stuck in the wood and the frictional force between the metal and the wood is enough to hold it in place against the force of gravity trying to pull it down. When the knife penetrates the wood the wood is pusshed to the side and then springs back to make a good seal on the blade.
This frictional force can be quite strong. Many times, you'll see knife throwers jiggle the knife back and forth to loosen the frictional grip ( makes the knife cut a little bigger. and finally remove it.
Oh ok. i was wondering what the force was...so it's friction?
I guess I should really just pick up that physics textbook...
CuriousBanker said:
Hi,
... Anyway, I was at a renaissance fair today, and there was a knife thrower. The tip of the knife strikes the wooden wall, and the knife gets stuck in the wall. But how? I know if the entire knife went in the wall, obviously gravity is pulling it downward and it is resting in the wall.
walls are usually vertical so gravity, I imagine isn't playing much part in the knife staying in the wall. rather gravity would be trying to get the knife down to the lowest place ... namely the floor.
the thing keeping the knife in the wall is the adhesion and frictional forces between the knife blade and the wall material. Imagine the wall being made out of different materials
and think about how the strength and density of those different materials would affect the friction between the 2 surfaces. High friction ... the knife stays in there, low friction the knife falls out ... gravity overcomes the frictional forces
just my thoughts :)
one of our guru's may light to put a few physics formula into the situation :)
Dave
Gravity is a very weak force that exists between masses. It's so weak that it's usually only a concern when we're dealing with astronomical-sized objects (such as the Earth attracting the knife). However, the gravitational force between the knife and the wall is quite insignificant. I would guess that even a single bacteria would be strong enough to overcome it...
davenn said:
the thing keeping the knife in the wall is the adhesion and frictional forces between the knife blade and the wall material. Imagine the wall being made out of different materials and think about how the strength and density of those different materials would affect the friction between the 2 surfaces. High friction ... the knife stays in there, low friction the knife falls out ... gravity overcomes the frictional forces
I would add these little details:
It is static friction, the kind of friction that exists when two surfaces are not sliding past one another.
It is a different mechanism from kinetic friction, the kind of friction that you have when sliding is taking place.
Static friction is produced by the overlap of the electron clouds in the two surfaces, much weaker than covalent bonding but related to it in origin.
The force that the wall exerts on the knife is called normal force because the force is perpendicular to the surfaces, and normal means perpendicular.
The two surfaces in contact are characterized by a number called the coefficient of static friction, which is determined by what materials the wall and the knife are made of, as well as smoothness or roughness.
The magnitude of the static friction is calculated by multiplying the coefficient of static friction by the normal force.
  • · Replies 16 ·
  • · Replies 67 ·
  • · Replies 38 ·
