New Reply
Is this line integral computation correct? (Green's Thm application)
Share Thread Thread Tools
Aug20-12, 12:20 AM   #1
Find the value of the line integral
[itex]\int[/itex] C(e-x^3 - 3y)dx + (tan y + y4 + x) dy
where C is the counterclockwise-oriented circle of radius 4 centered at (0,2).
3. The attempt at a solution
First off, I didn't think this was path independent since the derivative of the dx term in respect to y equals -3 which doesn't equal the derivative of the dy term with respect to x, 1.
After getting stuck on some direct approaches, I realized it is probably a Green's Thm application.
This then translates to [itex]\int[/itex][itex]\int[/itex] 4 dA. So in polar coordinates the path of the circle is
x = 4 cos [itex]\vartheta[/itex]
y = 4 sin [itex]\vartheta[/itex] + 2
This is where I get unsure. To try and get the limits on r I tried to say r = sqrt (x + y) and then plugged in the paramatized equations for x and y. This simplified to r = sqrt (20 + 16 sin [itex]\vartheta[/itex]). So then I thought that r varies from 2 to this general thing and hence
[itex]\int[/itex] [itex]^{2pi}_{0}[/itex] [itex]\int[/itex][itex]^{\sqrt{20 + 16 sin\vartheta}_{2}}[/itex] 4 r dr d[itex]\vartheta[/itex].
Is this right? Note that the limits with respect to r is suppose to be 2 to that sqrt expression, the two just kept popping up a little below and to the right...
In particular is this a correct way to find the respective limits of integration? Thanks!
2. Relevant equations
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Aug20-12, 02:31 AM   #2
Recognitions:
Gold Membership Gold Member
Quote by Fractal20 View Post
[itex]\int[/itex] C(e-x^3 - 3y)dx = (tan y + y4 + x) dy
Check that you've typed the integral correctly, as it doesn't make much sense as it is.
Did you mean:
$$\int_C (e^{-x^3}-3y)dx+(\tan y + y^4+x)dy$$
Aug20-12, 03:03 AM   #3
1. The radius of the circle is given directly in the problem statement.
2. The double integral of a constant is equal to the constant multiplied by the area of the domain of integration, which is a circle of a known radius here.
Aug20-12, 09:04 AM   #4
Oops, sorry that was suppose to be a + rather than =. Thanks Voko, I should have seen that. That clears it all up for me.
New Reply
Thread Tools
Similar Threads for: Is this line integral computation correct? (Green's Thm application)
Thread Forum Replies
Line Integral, Green's Theorem Calculus & Beyond Homework 9
Green's Theorem and Line Integral Calculus & Beyond Homework 5
line integral with green's theorm Advanced Physics Homework 4
vector calculus - line integral computation Calculus & Beyond Homework 1
Line Integral + Green Theorem problems Calculus & Beyond Homework 4
