| New Reply |
Average Acceleration Question |
Share Thread | Thread Tools |
| Aug21-12, 08:49 PM | #1 |
"A bullet is fired through a 5.0 cm thick board of some material. The bullet strikes the board with a speed of 200 m/s, and emerges out the other end at 100 m/s. 2. Relevant equations a= (change in velocity)/(change in time) average velocity = .5(initial v + final v) 3. The attempt at a solution a= (-100 m/s)/(.000333 seconds) = -300300 m/s^2 I found .000333s as the time it took for the bullet to pass through the board, using the average velocity of 150 m/s. Is this correct? SOLVED. |
| Aug22-12, 12:08 AM | #2 |
Recognitions:
It helps, if you are unsure of your reasoning, to relate what you did with some other representation... eg. from your equations:
ave speed = distance over change in time:[tex]\frac{d}{T} = \frac{1}{2}(v + u) \Rightarrow 2d = (v + u)T[/tex]... using distace d, change in time T, final velocity v, initial velocity u. acceleration is change in speed over change in time:[tex]a = \frac{v - u}{T} \Rightarrow v = aT + u[/tex] Soooo... combining them:[tex]2d = \big ( (aT + u) + u\big )T = aT^2 +2uT \Rightarrow d = uT + \frac{1}{2}aT^2[/tex]... which you will recognize as a kinematic equation. ... so what you've done is basically the same as assuming a constant acceleration, and is consistent with other physics you know. |
| New Reply |
| Tags |
| 5.0 cm, acceleration, board, bullet, velocity |
| Thread Tools | |
Similar Threads for: Average Acceleration Question
| Average Acceleration and Velocity Question | Introductory Physics Homework | 2 | ||
| Help verify this question about average acceleration? | Introductory Physics Homework | 4 | ||
| Average Acceleration Question | Introductory Physics Homework | 1 | ||
| Question about average acceleration | Introductory Physics Homework | 9 | ||
| help needed with average acceleration question | Introductory Physics Homework | 1 | ||
