Does air friction increase a gunshot bullet's range?
The discussion revolves around the effects of air friction on the range of a bullet when fired, comparing scenarios in air versus a vacuum. Participants explore concepts related to drag, lift, and the dynamics of bullet flight, including the implications of bullet spin and the Magnus effect.
  • Some participants propose that air friction reduces a bullet's range due to energy loss as heat, while others suggest that the bullet remains in the air for a similar amount of time in both environments.
  • One participant argues that although bullets do not glide, they experience increased vertical drag in air, which could slightly extend their time in flight.
  • Another participant mentions buoyancy as a factor that reduces the vertical net force on the bullet in air.
  • There is a discussion about the potential for lift if a bullet is fired at an angle with sufficient spin, although concerns are raised about stability and precession affecting this possibility.
  • Participants discuss the Magnus effect and its implications for a spinning bullet, with one providing a mathematical derivation related to lift generation.
  • Some express skepticism about the practical significance of any lift effect, emphasizing that decreased velocity due to friction likely negates any potential increase in distance traveled.
Participants do not reach a consensus on the overall impact of air friction on bullet range. While there are shared views on the effects of drag and the lack of lift, differing opinions exist regarding the significance of these factors and the potential for lift under certain conditions.
Limitations include assumptions about bullet shape, spin, and the idealized conditions under which the Magnus effect is analyzed. The discussion also reflects varying interpretations of the practical implications of air friction on bullet trajectory.
Hivoyer
Would a bullet have longer trajectory,because the air helps it ''glide''?Does this mean that if you fire the same gun and bullet in vacuum and in the air the one fired in the vacuum will fall to the ground a lot more quickly?
Do you mean create lift?
In reality, nope. Bullets will (well, any accurate ones) rotate very rapidly and be uniform about the rotational axis. Ergo, no lift produced. A bullet with an aerofoil cross section would be terribly hard to stabilize.
You've asked two questions. Air friction would reduce the range. However, both bullets would remain in the air for very similar amounts of time.
Air friction will produce heat (as does any friction) in the air and in the bullet. This heat energy has to come from somewhere according to the conservation of energy. The friction actually takes away from the kinetic energy of the bullet, making it into heat energy. A decrease in kinetic energy means the bullet is being slowed down by this friction.
To answer your question more specifically, the bullet will be pulled to Earth by gravity at the same rate with or without the air friction because, as LJW said, it doesn't create any lift.
Actually, the fired bullet does stay in the air slightly longer. Even though it does not glide, the vertical drag is effectively increased. But it's not nearly enough to offset the loss of speed due to friction, so the range is still significantly reduced.
Might I add that in air the bullet also experiences bouyancy, which reduces the vertical net force on the bullet.
Note that I said "very similar", not "the same"
It's true that the bullet in the atmosphere will stay in the air for very slightly longer. For practical purposes, not significant.
If by practical purposes you mean something like aiming, that's absolutely correct. The way you usually aim at a distant target is compute the time of flight (usually from table), and use that to get the drop distance (assuming free fall in vacuum) and distance carried by wind (time difference with flight in vacuum multiplied by wind velocity). So the only relevant effect of drag is impact on time of flight.
Why can't a bullet glide? At least theoretically. If you fire at a distant target, you don't fire the bullet horizontally, but slightly inclined. If the bullet had enough spin, it should keep that inclined axis, even when its vertical velocity is reduced and negated by gravity. So the bullet axis is not aligned with the velocity anymore, and a lift component is possible.
I guess you would need bullets with more spin, and less drag (pointy back) to make advantage of this. And the Magnus effect would pull the spinning bullet sideways.
Because if its center of pressure is even slightly off center of mass, which is almost a guarantee, it will precess.
i was wondering if anyone knew how to derive the magnus effect equation?
I can confirm this with a quick simulation, under the assumption of a spherical bullet without rotation - but I do not think those things change the result.
Sort of. At least, in a somewhat idealized setup, which should give you a qualitative answer, at least.
Using Kutta-Joukowski theorem, lift per infinitesimal slice can be computed via circulation.
[tex]dF_L = \rho \Gamma v dl[/tex]
Where gamma is the circulation. Technically, all three of these should be taken at infinity. However, if you assume a laminar flow, the circulation is going to be the same everywhere, and you know circulation at the boundary of the sphere. Circulation is given by the integral along a closed curve.
[tex]\Gamma = \int_C v\cdot ds[/tex]
And the layer at the boundary of the sphere moves along with the sphere. That gives Γ=2ωπr², where ω is angular velocity component perpendicular to v. The total lift can then be computed by integrating over all slices of the sphere.
[tex]F_L = \int_{-R}^{R} 2\pi \rho r^2 (\omega \times v) dl = \frac{8}{3}\pi \rho R^3 \omega \times v[/tex]
Which gives you the correct ωxv dependence of lift. How close the coefficient is going to be, however, I have no idea.
Edit: I just sort of assumed spherical shape in that last integral. If it's a cylinder, or whatever, you'll need to correct for whatever r(l) dependence you actually have.
I can go along with AT because I have seen a video of a shell fired from a tank gun. It definitely spins and stays at an angle that would give lift. I don't know how big the effect would be because that was not the main feature of the video...it was about high speed photography.
thankyou k^2
Even if the time spent in the air is longer, I doubt that the distance traveled is longer, since the velocity is decreased by friction.
  • · Replies 23 ·
  • · Replies 17 ·
  • · Replies 29 ·
  • · Replies 35 ·
