Need help from Electrical Engineers Please (CFC60 and CFC36 reqs)
  • Thread starter Thread starter WCIGAFETW
    Electrical
The discussion revolves around the application of filters to acceleration data, specifically focusing on the Channel Filter Class (CFC) specifications, including the meaning of "Stop Damping" in decibels. Participants explore the implications of using different filter types, such as Butterworth, Chebyshev, and elliptic filters, in the context of sensor data processing.
  • One participant expresses uncertainty about the meaning of "Stop Damping" in the context of CFC specifications and seeks clarification on the parameters for CFC36.
  • Another participant suggests that "Stop Damping" may refer to the gain in the stop-band and provides a link to a relevant PDF for further reading.
  • A different participant critiques the choice of a Butterworth filter, arguing that it may not be suitable due to its ringing characteristics compared to Chebyshev and elliptic filters.
  • One participant proposes that the only critical parameters for their application are the cutoff frequency and the order of the filter, while still using a Butterworth filter due to its standardization by SAE.
  • There is a discussion about whether cutoff frequencies and "-3 dB limit frequency" are synonymous, with some participants expressing hesitance to equate them directly.
  • Concerns are raised about the implications of filter choice in real-world applications, particularly in vehicle control systems and crash tests.
Participants do not reach a consensus on the best filter type to use, with some advocating for Butterworth filters while others argue for Chebyshev or elliptic filters. The discussion contains multiple competing views regarding the definitions and implications of filter parameters.
Participants express uncertainty about the definitions of certain filter parameters and their implications for data analysis. There are also unresolved questions regarding the relationship between cutoff frequencies and "-3 dB limit frequency."
WCIGAFETW
Hello everyone,
I am needed to apply a filter to some acceleration data. That I think I can handle (I have chosen a Butterworth). What I do not understand are the CFC (Channel Filter Class) specifications. In particular, I do not know what a "Stop Damping" number specified in -dB is. Below is an example of a CFC60.
Filter type
CFC 60
Filter parameters
3 dB limit frequency: 100 Hz
Stop damping: –30 dB
Sampling frequency: At least 600 Hz
My sensor samples at 400 Hz which puts my CFC at about 36. Please correct me if I am wrong. At CFC 36, what would my parameters be? Do they define cut-off frequencies?
Thank you for any help. Google-skill"z" are failing me.
David
Why has my answer disappeared?
A butterworth is the worst possible choice because it rings much worse than the others, as compared at the same selectivity, and this may be important for an accelerometer filter. A Chebychev is better, an elliptic even better; the good ones among known names are minimum-Q elliptic, hourglass, and the best is inverse (or type II) Chebychev.
Your "stop damping" must be the attenuation in the stop band. To define a simple low-pass, you must still tell the corner frequency of the stop band.
The main difficulty here is that your software uses terms uncommon to the filter people.
Thanks for your help Enthalpy and NascentOxygen. I have been doing some reading into this stuff and think the only real parameters I need to be concerned with are the cutoff frequency and the order of the filter. I am still running a Butterworth (sorry Enthalpy) as it is the filter used by SAE for all of their analysis.
I found a 2nd order filter online with the coefficients explained and applied it to my data.
http://biomech.byu.edu/Portals/83/docs/exsc663/part01/filtering_considerations.pdf
The equation and coefs are simple enough. However, I am making assumptions as to what a CFC36 would be. I believe the parameters for that filter class would be as follows:
-3 dB limit frequency: 60 Hz
Sampling frequency: At least 360 Hz
Are cuttoff frequencies and this "-3 dB limit frequency" the same? Are these two things synonymous with rolloff frequencies? If these numbers and my assumptions are correct, my cutoff frequency to be applied is 60 Hz.
Thanks again for the assistance.
David
-3dB and rolloff frequency are I'd say synonymous with "corner frequency". But "cutoff", I'm hesitant to say one way or the other.
If this is performed in software, then you could at a later stage easily double or halve the -3dB frequency and see whether there is any significant change in your results. If there is little change, then it's probably safe to conclude that you are capturing all significant components.
The Tchebychev is very underdamped, so shows a lot of ringing compared to a Butterworth of the same order.
Please tell us that you're not programming the control system of a real vehicle.
The aim of a filter is not to have a certain number of poles, but a certain selectivity, for which even the type I Chebychev has fewer poles and lower Q factors. This must be the reason why it rings less than a Butterworth at identical selectivity, and an elliptic even less.
Or crash tests! I believe to remember such names like CFC36.
Fun: I studied and defined filters for CrashSoft, with much better ringing than the common ones, with a trainee called David like the OP here.
  • · Replies 0 ·
  • · Replies 28 ·
