How dense would an object have to be in order to hold up a makeshift earth.
  • Context: Undergrad
  • Thread starter Thread starter Tirent
    Earth
The discussion centers around the hypothetical scenario of calculating the density required for a pillar to support an Earth-sized object, inspired by the God of War franchise. Participants explore various assumptions about the pillar's dimensions and the conditions under which it would need to support the weight of the Earth.
  • One participant proposes calculating the density of a pillar that could support an Earth-sized planet, providing specific dimensions and conditions for the pillar.
  • Another participant questions the relevance of density, suggesting that material strength and stiffness are more critical factors in determining whether the pillar can support the weight.
  • A further contribution emphasizes that the strength of the Earth itself must also be considered, using an analogy of lifting an elephant with a sewing needle to illustrate the point.
Participants do not appear to reach consensus, as there are competing views on whether density or material strength is the more relevant factor in this scenario.
The discussion involves assumptions about gravity, the dimensions of the pillar, and the nature of the materials involved, which may not be fully resolved or defined.
Tirent
I know that this may be very odd,but I wanted to calculate the density of the pillar of the world from the God of War franchise.This pillar by itself as small as it is is able to hold the Earth up quite easily. So i just wanted to have an estimation of how dense an object like a pillar would have to be in order to hold up an Earth sized planet with the same weight of earth.
Let's just factor these in and just assume that
>The gravity is the same as earth's
> The pillar is 1000m in height and has a 4x4 base so a side would be about 100m
>The pillar is on top of a stable flat surface.
>The pillar is a rectangular prism.
Also just a quick question,which of the following could successfully hold up this fake Earth without being crumbled?
1.A sky scraper
2.10 sky scrapers
3.A Mountain of 1000 meters
4.Mount Olympus
5.All of the mountains in the Earth put together into one giant mountain
6.an island separated from the water that is about the size of Jamaica
7.The same as above but the island is the size of Texas
8.A continent ripped from earth(Africa)
9.multiple Africas(3)
10.A moon
Or simply can you just tell me how much something would have to weigh in order to hold this fake Earth up.
Any input?
Not even on the list?
Density is not the relevant parameter here.
The material strength and stiffness parameters determine if the pillar will support the weight or not.
It's not just the strength of the pillar that's important here but also the strength of the earth. Try lifting an elephant up with a sewing needle. The elephants skin isn't strong enough.
10K
