Why are reference angles necessary in trig
The discussion revolves around the necessity and understanding of reference angles in trigonometry. Participants explore their role in simplifying calculations and their historical context in relation to trigonometric tables.
  • Participants discuss the definition of reference angles and their relationship to acute angles. Some question their necessity, while others suggest they are a convenient tool for using trigonometric tables.
The discussion is ongoing, with participants sharing different perspectives on the usefulness of reference angles. Some have provided clarifications and examples, but there is no explicit consensus on their necessity.
There is mention of historical practices in trigonometry, particularly before the advent of calculators, which may influence the understanding of reference angles. Some participants note the limitations of trigonometric tables that only include angles up to 90 degrees.
Luke77
Why are reference angles necessary in trigonometry. I understand they are the acute version of an obtuse angle.
Hi Luke77! :smile:
I've never come across them before. :confused:
Apparently, they're the difference between the angle and the nearest multiple of 180° (π).
(so they're always between 0° and 90°)
In other words, trig tables only give you measurements up to 90°, so you find the "reference angle", look up the trig of that in the trig table, and if necessary multiply by minus-one. :smile:
(see http://www.mathwarehouse.com/trigonometry/reference-angle/finding-reference-angle.php for some examples)
Reference angles aren't "necessary". They are convenient, especially back in the years 'BC' (Before Calculators) when you had to look up trig functions in tables. Rather than have tables that extended to, say, 135 degrees, 225 degrees, and 315 degrees, they just went from 0 to 90 degrees so you could look up the "reference angle", 45 degrees, for all those and then apply the correct sign yourself.
Thanks!
  • · Replies 22 ·
