Better Best
- 4
Why?
The discussion revolves around the perception of water's weight compared to its appearance, exploring concepts related to mass, density, and the behavior of fluids. Participants engage in a conceptual examination of why water may feel heavier than it looks, touching on psychological aspects and physical properties.
Participants express varying opinions on the nature of the question and the factors contributing to the perception of water's weight. There is no consensus on a singular explanation, with multiple viewpoints and interpretations presented.
Some participants reference psychological aspects of perception and the physical properties of fluids, but the discussion remains open-ended with unresolved questions about the relationship between appearance and weight.
Better post: 4048442 said:Well, idk. You're able to easily move it around and stuff but when you try to pick it up it takes effort.
ModusPwnd said:Always slipping through your fingers?
Better post: 4048451 said:Would that make it heavy?
In physics, a fluid is a substance that continually deforms (flows) under an applied shear stress.
Drakkith said:Water moves around things because it is a fluid. (It is also a liquid)
To quote wiki:
How HEAVY something may be is related directly to its mass.
Better post: 4048467 said:Oh, ok. Well then can you explain that to me? Because a balloon full of air and a balloon full of water the same size basically look similar, but the one with water is much heavier. How is that so?
Better post: 4048467 said:Because a balloon full of air and a balloon full of water the same size basically look similar, but the one with water is much heavier. How is that so if they're taking up the same amount of space?
Better post: 4048467 said:Oh, ok. Well then can you explain that to me? Because a balloon full of air and a balloon full of water the same size basically look similar, but the one with water is much heavier. How is that so if they're taking up the same amount of space? Stupid question, I know.
