Solving Linear Combinations of Positive Stamp Values
The discussion revolves around the problem of determining which values can be expressed as linear combinations of two positive stamp values, denoted as a and b. The focus is on the conditions under which certain values can be formed, particularly when a and b are coprime versus when they share a common factor greater than 1. Participants explore the implications of these conditions and seek to prove specific properties related to consecutive numbers that can be formed.
  • One participant notes that if the stamps a and b have a highest common factor greater than 1, there are infinitely many 'bad' numbers that cannot be formed, while if they are coprime, all numbers can eventually be expressed as combinations of a and b.
  • Another participant suggests that the upper limit of non-possible numbers might be represented by the formula ab - a - b, based on various examples.
  • A participant clarifies that a and b should be non-negative and discusses the implications of this in terms of forming integers through combinations of the stamps.
  • One participant proposes a specific case where B = A + 1 and presents a series of terms that fulfill the necessary requirements for forming combinations, starting from a specific value.
Participants generally agree on the requirement that a and b must be non-negative. However, there are differing views on the specific properties of the combinations and the implications of the upper limit of non-possible numbers, indicating that the discussion remains unresolved.
Participants have not fully resolved the mathematical steps needed to prove the properties of consecutive numbers that can be formed from the linear combinations of a and b. There are also assumptions regarding the definitions of 'bad' numbers and the conditions under which certain values can be expressed.
adamg
this is quite a classic problem i think but I am having difficulty finishing it off. If we have two stamps of positive values a and b, (greater than 1), what values can be expressed as a linear combination of these 2 stamps. If the stamps have a highest common factor greater than 1, then there are infinitely many 'bad' numbers. But if the numbers are coprime, after a certain point, all numbers are possible. For instance, with 5 and 8, in the list of possible numbers, you eventually get 28,29,30,31,32, therefore by adding 5's every other number is possible.
Can anyone help me prove the fact the if you have a and b, with a<b, then eventually you get 'a' consecutive numbers in the list of possibles. (therefore making all subsequent numbers possible).
Any other angle welcome!
Mathematics news on Phys.org
think the upper limit of not-possible numbers may be ab-a-b on the basis of a number of examples
I presume you mean for A and B to be non-negative. Since we have, in the example given, the case of 5(-3) + 8(2) =1, we see that every integer is possible.
In the example given: 5A+8B =30, and 5A+8B=32, the first case demands that 5 divide B and the second that 8 divides A. So those cases are only solved in non-negative terms with a zero for A or B. Assuming A less than B, to get A successive values, one of them will be divisible by A giving us a zero coefficient for B.
So I wonder if that was how you are seeing the problem?
yes, a and b must be non-negative, as must the numbers of each i.e. can't have negative numbers of stamps.
Well, here is a start: Let B = A+1. Look at series of A terms: (A+1) + A(A-1)=A^2+1; 2(A+1)+A(A-2)=A^2+2...A(A+1) + A(A-A) =A^2+A.
This series fulfillls the necessary requirements and starts at (A+1) +A(A-1) =A^2+1.
