Aki
- 83
I don't understand why the derivative of e^x is e^x itself.
The discussion centers around the question of why the derivative of the function e^x is equal to e^x itself. Participants explore various explanations, including definitions, properties of exponential functions, and connections to integrals and areas under curves. The conversation includes both conceptual and mathematical reasoning.
Participants express a range of views, with some agreeing on the properties of e^x and its derivative, while others raise questions and challenges regarding the explanations provided. The discussion remains unresolved on several points, particularly regarding the connections between different mathematical concepts.
Some participants note the limitations of their arguments, including assumptions about definitions and the need for clarity in the relationships between derivatives and integrals. There is also an acknowledgment of the complexity involved in proving uniqueness of solutions to differential equations.
tongos said:first consider the following
the integral of In(x) is equal to xInx-x.
the value of the graph of e^x is the same as doing the e^x bound on the Inx graph. so we could plug in e^x for x into xInx-x. Giving xe^x-e^x as the area inside of the Inx graph. Now this is below the curve, we are trying to find the area above the curve on the Inx graph. So the rectangle area is equal to x(e^x). And the area of the region is now xe^x-(xe^x-e^x)=e^x
I hope this logic was right.
How can you show that the equation f'(x) = f(x) has a unique solution?
tongos said:one can only confuse derivatives and integrals only when dealing with e^x. I shouldn't drop the C, which is the constant. I have a question, that probably most of you guys with think as easy, but is there any other function where the derivative of the function is equal to the function itself? prove or disprove.
