Improve Your Understanding of Electromagnetism with These Recommended Textbooks
The discussion revolves around recommendations for textbooks on electromagnetism, particularly aimed at a Mechanical Engineering major seeking to strengthen their understanding of the subject. The scope includes introductory and advanced texts, as well as supplementary materials related to circuits and electromagnetic theory.
  • Homework-related
  • One participant inquires about suitable textbooks for electromagnetism, expressing a desire to improve their understanding of circuits and E/M fields.
  • Another participant suggests "Fundamentals of Physics" by Halliday, Resnick, and Walker for introductory study, noting the availability of various editions.
  • A recommendation is made for "Engineering Electromagnetics" by Hayt and Buck for upper-class undergraduate study, with the suggestion to work through the problems to prepare for Griffith's "Intro. to Electrodynamics."
  • Another text, "Engineering Electromagnetics" by Nathan Ida, is mentioned as a good option, although the participant has not personally read it.
  • "A Student's Guide to Maxwell's Equations" by Fleisch is proposed as a quick supplementary read.
  • The "Feynman Lectures" Volume II is recommended for its clear and thought-provoking presentation of material, though it is suggested to read it after gaining a foundational understanding of the subject.
  • One participant argues that if the original poster has a solid grasp of classical mechanics, they should consider starting with Griffiths, as it is the standard for upper-level physics majors, while noting that engineering texts may skip more physics-oriented material.
  • It is noted that engineering texts often provide insights into antennas and transmission line theory, which may be of interest to some learners.
  • A suggestion is made to consider Agrawal's text specifically for circuits, described as a novel exposition in circuit theory.
Participants express differing views on the appropriateness of various textbooks for the original poster's level of understanding and needs. There is no consensus on a single best approach, as recommendations vary based on the perceived background and goals of the learner.
Some participants highlight differences in focus between physics-oriented texts and engineering-oriented texts, noting that engineering texts may not cover certain theoretical aspects in depth. The discussion reflects varying opinions on the order in which to approach the material and the suitability of specific texts for different learning objectives.
cmmcnamara
Hi all,
Just got a quick question regarding textbooks revolving around electromagnetism studies. I'm a Mechanical Engineering major and I have a firm grasp on pretty much all classical mechanics and have begun exploring some quantum studies for personal pleasure. I've found however that I am extremely weak in my application of electromagnetism, even with basic things like circuits and E/M fields. Could I get some textbooks surrounding these topics? I've seen Griffin's Electrodynamics mentioned around the forum quite a bit but I'm not sure if its the right tree to be barking up yet. Thanks in advance!
For introductory electromagnetism, I'd suggest "Fundamentals of Physics" by Halliday, Resnick and Walker. There are a large variety of editions and volumes for this particular text. The one linked below is the full edition, but you may be able to find a volume that only contains Chapters 22-33 (Part 3), which cover the basics of E&M.
https://www.amazon.com/dp/047122863X/?tag=pfamazon01-20
For upper-class undergraduate study, I recommend reading "Engineering Electromagnetics," by Hayt and Buck. Reading this book from cover-to-cover and working the problems should sufficiently prepare you for Griffith's Intro. to Electrodynamics.
https://www.amazon.com/dp/0072551666/?tag=pfamazon01-20
Also, I've read that "Engineering Electromagnetics" by Nathan Ida is very very good (although I haven't had the pleasure of reading it).
https://www.amazon.com/dp/0387201564/?tag=pfamazon01-20
For a quick/supplementary read, you may want to try "A Student's Guide to Maxwell's Equations" by Fleisch.
https://www.amazon.com/dp/0521701473/?tag=pfamazon01-20
Above all else, I recommend reading the "Feynman Lectures" Volume II. It won't give you any examples to work through, but it delineates the material in a clear-concise and thought-provoking way.
https://www.amazon.com/dp/0201510049/?tag=pfamazon01-20
Thanks for all the suggestions!
If you truly have "a firm grasp on pretty much all classical mechanics" (I assume that means you're in your senior year or just graduated) then I would say go straight to Griffiths. Griffiths is the standard for upper-level physics majors whereas the "Engineering Electromagnetic" texts mentioned above is meant for upper-level electrical engineering majors.
The difference is that the engineering texts tend to abbreviate/skip "more physicsy" material like charged-particle dynamics, energy/momentum transfer, boundary-value problems with special functions, special relativity, etc. The engineering texts will even intuit some things instead of mathematically proving them (e.g. not using delta functions to prove the divergence of a point charge).
What's nice about the engineering texts is that they will usually give an introduction to antennas and spend some time on transmission line theory. If you care about such things, then I would start with Griffiths and supplement it with one of the engineering texts. It's also good to know that Griffiths is probably one of the best textbook authors out there in terms of ability to explain complicated material.
The Feynman lectures are a good read for all of basic physics, but I think that it's a more suitable read only after you know the material. You learn the material first, then you read Feynman to see what the physics really means.
I should add that if you're looking specifically for circuits, then you might want to look at Agrawal (https://www.amazon.com/dp/1558607358/?tag=pfamazon01-20). It's a truly novel exposition in how circuit theory is taught. It also looks like the course based off of this book is being offered for free later this month (www.edx.org).
  • · Replies 21 ·
  • · Replies 26 ·
13K
  • · Replies 102 ·
11K
16K
