Combining sub-matrices into global matrix
  • Thread starter Thread starter Aerstz
    Global Matrix
The discussion revolves around the process of combining sub-matrices into a global stiffness matrix for simple truss analysis, focusing on the mathematical operations involved and the challenges encountered in the final stages of the solution. The context includes homework-related inquiries and technical explanations regarding matrix assembly in structural analysis.
  • Homework-related
  • One participant inquires whether overlapping values in the global matrix should be simply added together to form a single value, using specific examples of matrix entries.
  • Another participant confirms that adding the values from individual elemental matrices to form the global matrix is indeed the correct approach.
  • A further contribution provides a coding example in Fortran, illustrating how to add contributions from a triangular element into a larger global matrix, detailing the specific indices involved.
  • A participant corrects a typo in their previous post regarding matrix indices, indicating the importance of accuracy in mathematical expressions.
  • One participant expresses gratitude for the shared coding example and mentions a struggle with understanding a specific transition in a provided example, seeking clarification on the origin of certain values.
  • Another participant suggests that determinants can be used to solve a related problem, mentioning a method involving the stiffness matrix and load vector, while noting a common factor in the numbers involved.
  • A participant expresses appreciation for the insights shared, indicating a desire for more comprehensive explanations typically absent from textbooks.
Participants generally agree on the method of combining values from elemental matrices into a global matrix, but there are unresolved questions regarding specific calculations and transitions between stages in the process.
Some participants express uncertainty about specific numerical values and the steps involved in the matrix assembly process, indicating that further clarification is needed on certain aspects of the calculations.
Aerstz
Combine five element matrices into single matrix forming a global stiffness matrix for simple truss analysis (five elements, four nodes).
-See attached image-
Where the four sub-matrices overlap in the global matrix two or three values/numbers occupy the same position in the global matrix (two separate values for AA, three separate values for BB, and so on). Should I simply add these values to form a single value for the global matrix? For example: if AA1 = -10, and AA2 = +5 should I simply combine them as AA = -10+5 = -5?
Is it really as simple as that?
Thanks.
Yes, that is the way you build a global matrix from individual elemental matricies.
Thank you very much. I'm assuming your post is based on my AA = AA1 + AA2 and not just the matrix image I posted! I very much appreciate your confirmation.
Suppose you had a triangular element with nodes 2,6,8 at the corners. You would add it into the global matrix as follows where A could be a 100X100 matrix. a is the 3X3 contribution from the element. Below would be the coding in Fortran.
The first indice is the row, the second is the column.
A(2,2)=A(2,2) + a(1,1)
A(2,6)=A(2,6) + a(1,2)
A(2,8)=A(2,8) + a(1,3)
A(6,2)=A(6,2) + a(2,1)
A(6,6)=A(6,6) + a(2,2)
A(6,8)=A(6,8) + a(2,3)
A(8,2)=A(8,2) + a(3,1)
A(8,6)=A(8,6) + a(3,2)
A(8,8)=A(8,8) + a(8,3)
In my last equation there is a typo.
a(8,3) should be a(3,3).
Thank you. It was kind of you to post that, and I appreciate it. Apologies for not replying more promptly but I had a couple of deadlines to meet and my mind was away from the matrix problem for a day or two.
Now my mind is back on this issue I am much more confident but stuck at the final stage. I’ve attached an example someone else produced which shows three stages. I can get from stage one to stage two but not two to three. I don’t know where the 160083 came from, or the three bracketed numbers. Any help with this would be very welcome!
The problem is solved by using determinants where for a1 you divide the determinant of the stiffness matrix with the load vector substituted for the first column by the determinant of the original stiffness matrix. All numbers are evenly divisible by 3 so it is factored out.
Thank you once again. Your reply to me is just the sort of thing I want to read in the textbooks, yet it is nearly always missing and so I often learn little from them. Perhaps I've just been reading the wrong books!
  • · Replies 32 ·
  • · Replies 19 ·
