Solving Forces and Angles to Load Fuel Drum
  • Thread starter Thread starter k3l
    Angles Forces
The discussion revolves around a scenario involving a plank used to support a load, specifically focusing on the mechanics of forces and angles. The original poster describes a situation where a plank broke under a weight of 166 kg when supported horizontally, and now the same plank is being considered for use as a ramp to load a 197 kg fuel drum.
  • Participants discuss the reasoning behind the plank's ability to support a greater weight when inclined, with references to the reduction of the normal force component due to the angle of the plank. There are attempts to calculate the minimum angle required for the plank to safely support the fuel drum.
The discussion is ongoing, with some participants providing mathematical insights and reasoning related to the forces acting on the plank. There is an exploration of the concepts of gravitational force components and their implications for the problem at hand.
Participants are working under the constraints of the problem as presented, including the specific weights involved and the mechanics of the plank's support. The original poster expresses uncertainty about how to approach part a) of the question.
k3l
hi, i need help on a question
its like... there is a operator supported a plank horizontally by its two ends, but when loaded bricks on its centre and found that the weight of 166kg of bricks was just enough to break the plank. But an identical plank is now being used as a ramp to load a full 200L fuel drum onto a truck. The drum and its contents have a mass of 197kg.
a) Carefully explain why the operator could still use this plank to load the fuel drum.
b) what is the minimum angle to the horizontal at which the plank can still used to load the drum?
i don't know where to start... as i don't know how to answer part a) :mad:
min angle would be = cos-1(166/197)
and the reason the greater weight could be carried is b/c when the plank is at angle the internal moment arm is less
The original plank broke at 166 kg because the gravitational force NORMAL to its surface exceeded the plank's capacity. When the plank is tilted, the component of gravitational force NORMAL to the surface is reduced by a factor of cos(A), where "A" is the plank's tilt angle with respect to horizontal ground. Thus, the minimum "A" required for 197 kg can be determined from:
(197)*cos(A) = (166) <--- (derive this yourself by resolving grav force into components normal and parallel to plank surface)
how do i attach a document
plank
this should help
  • · Replies 39 ·
