Have I done this differential equation correctly?
The discussion revolves around solving a second-order linear homogeneous differential equation, specifically y'' + 6y' + 8y = 0, with initial conditions y(0) = 1 and y'(0) = 0. Participants are examining the correctness of the solution process and the values of constants derived from the initial conditions.
  • The original poster attempts to solve the differential equation and derive constants C and D from the initial conditions. Some participants question the validity of the algebraic manipulations used to isolate these constants, while others suggest checking the derived solution against the initial conditions and the original equation.
The discussion is ongoing, with participants providing guidance on verifying the solution and checking for consistency with the initial conditions. There is a recognition of potential errors in the algebraic steps taken, prompting further exploration of the correct approach.
Participants are encouraged to verify their results and ensure that the derived constants satisfy the simultaneous equations formed from the initial conditions. There is an emphasis on the importance of sanity-checking work throughout the problem-solving process.
jakobs
This is my first big differential equation that I have solved by myself, and I wanted to see if it is correct done, or what I have done wrong with it.
Would really appreciate if somebody could take a look on it.
y''+6y'+8y=0
when y(0)=1 and y'(0)=0
This is my solution
y''+6y'+8y=0
r2+6r+8=0
r=-3+- sqrt (9-8)= sqrt 1
r1= -2
r2= -4
y=Ce-2x+De-4x
y'=-2Ce-2x-4De-4x
y(0)=1 1=Ce0+De0=C+D
y'(0)=0 0=-2Ce0-4De0=-2C-4D
1=C+D
0=-2C-4D
I take 1=C+D and take -D on both sides so I get 1-D=C
I take 0=-2C-4D and take +2 on both sides so I get 2=C-4D
I now put in 1-D in it, and get 2=1-D-4D and that I can change to 3=-5D
I then take +5 on both sides and i get that 8=D
I go back to 1-D=C and I get that C=-7
I now take C and D and put them in the equation, so I get:
-7e-2x+8e-4x
Is this right, or have I made something wrong on the way?
This is a question you can answer yourself. Just check that you solution satisfies the equation and the initial conditions.
I don't want to come across as stupid, but how do I do that?
You have found y(x). Let x = 0, what do you get? It should be 1 as per initial conditions. Then differentiate your y(x). What is y'(0)? It should be 0 as per the conditions. Finally, differentiate that again, and plug your y, y' and y'' in the equation. Is it satisfied?
Also, since solving for C and D was a little subproblem, you should also check if your C and D satisfy the simultaneous equations. You should get in the habit of sanity-checking your work as you go.
jakobs said:
y''+6y'+8y=0
This is my solution
y''+6y'+8y=0
r2+6r+8=0
r1= -2
r2= -4
y=Ce-2x+De-4x
y'=-2Ce-2x-4De-4x
1=C+D
0=-2C-4D
-7e-2x+8e-4x
I think it gets wrong after what I highlighted.
Is there someone who can explain a little bit, so I can get in the right direction of solving this one?
You had 0 = -2C - 4D.
This somehow became 2 = C - 4D.
It is you who should explain how this is ever possible. You said "I take +2 on both sides", but that can't be it. +2 on both sides would get you 2 = -2C - 4D + 2
i see it now, I thought in the wrong way, I can't take the 2 away from C.
Can I do it like this?
2*1 + 0 = 2*(C+D) - 2C - 4D ⇔ 2 = 2C - 2C + 2D - 4D ⇔ -2D = 2 ⇔ D = -1
This gives 1 = C - 1 ⇔ C = 2
This is better. Now, check that your result satisfies the conditions of the problem.
Everything adds up, it must be correct!
What a great feeling I get from seeing that it is right :)
  • · Replies 18 ·
  • · Replies 18 ·
