Build a Balsa Wood Bridge: Explaining Arches & Compressive Strength
  • Thread starter Thread starter IGeekbot
    Bridge Wood
This discussion focuses on the design and structural considerations for building a balsa wood bridge, specifically addressing the use of arches and compressive strength. It establishes that arches distribute weight evenly, making them ideal for supporting heavy loads, while highlighting that balsa wood is stronger in tension than in compression. Key factors for determining arch size include the span of the bridge and the weight of materials used. The conversation also suggests the king post truss design as an alternative for those struggling with arch construction.
  • Understanding of arch design principles
  • Knowledge of compressive strength in materials
  • Familiarity with balsa wood properties
  • Basic skills in bridge design software
  • Research "balsa wood compressive strength" for material properties
  • Explore "arch design calculations" for determining arch dimensions
  • Learn about "king post truss design" as an alternative bridge structure
  • Utilize "bridge design software" for practical applications
Students, hobbyists, and engineers interested in bridge construction, particularly those participating in competitions or projects involving balsa wood structures.
IGeekbot
Can anyone or does anyone know where I can get a good explanation of how to figure out how big an arch should be for a bridge?
I am thinking of making one for our competition, and if I can't get that to work right, I will switch to a king post deisgn.
Oh, and is it true balsa and other types of wood are better in tension than compression because the cell walls will lose compressive strength if the water is taken away?
Try reference given below. Scroll down its page to find some excellent resources, including free bridge design software.
http://abcdpittsburgh.org/kids/kids.htm
Sure, I can provide some information on arches and compressive strength for building a balsa wood bridge. First, let's talk about arches. An arch is a curved structure that is used to span an opening, such as a bridge. It is an ancient architectural design that has been used for centuries due to its strength and stability. The curved shape of an arch allows it to distribute weight evenly, which makes it ideal for supporting heavy loads.
When building a balsa wood bridge, it is important to consider the compressive strength of the wood. Compressive strength is the ability of a material to withstand forces that are trying to squeeze or compress it. Balsa wood is a lightweight and low-density wood, which means it is not as strong in compression as other types of wood. However, it is still a popular choice for building bridges due to its high strength-to-weight ratio.
To figure out how big an arch should be for a bridge, you need to consider a few factors. First, you need to know the span of your bridge, which is the distance between the two supports. The larger the span, the bigger the arch needs to be to support the weight. Next, you should consider the weight of the materials used to build the bridge, as well as the intended load it will need to support. This will help determine the size and shape of the arch needed to distribute the weight evenly.
If you are having trouble figuring out the size of your arch, you can consider using a king post design. A king post truss is a simple triangular structure that can be used to support a bridge. It consists of a vertical post in the center with two angled members connecting it to the top and bottom chords. This design is often used for smaller bridges and can be a good alternative if you are struggling with the arch design.
Regarding your question about balsa wood being better in tension than compression, it is true that balsa wood is stronger in tension than compression. This is because the cell walls in balsa wood are made up of long fibers that are oriented in the direction of the tree's growth. When weight is applied to the wood, the fibers are pulled apart, which is better for tension forces. However, as you mentioned, if the wood is dried out or the water is taken away, it can lose some of its compressive strength. This is why it is important to keep the wood dry and avoid exposure to moisture when building a balsa wood bridge
12K
11K
9K
54K
  • · Replies 17 ·
