Volume Calculation of Y=(x+2)^(1/2) & Y=(2-x)(2+x)
  • Thread starter Thread starter Sombra
    Integration
The discussion focuses on calculating the volume of two functions rotated around the x-axis: Y = (x + 2)^(1/2) and the region enclosed by Y = (2 - x)(2 + x) and Y = 3x. For the first function, the volume is calculated using the formula V = π ∫ from -1 to 1 (x + 2) dx. The second part involves finding the intersection points of the functions, determined to be at x = -1 and x = 4, and calculating the volume using the method of disks or annuli, leading to a volume of 4π for the first function and a more complex integral for the second.
  • Understanding of integral calculus and volume calculation techniques
  • Familiarity with the disk and washer methods for volume of revolution
  • Knowledge of quadratic equations and the quadratic formula
  • Ability to visualize functions and their intersections graphically
  • Study the method of disks and washers for calculating volumes of revolution
  • Learn about the quadratic formula and its applications in finding intersections of functions
  • Explore integration techniques for calculating areas and volumes under curves
  • Practice problems involving volume calculations of rotated functions
Students and educators in calculus, mathematicians interested in volume calculations, and anyone seeking to enhance their understanding of integral calculus and geometric applications.
Sombra
if I want to find the volume of y= (x + 2) ^(1/2) about the x-axis with the boundaries of -1 and 1, then would it be :
V = pi times integral of (x+2) dx?? Its confusing trying to set it up. The volume of a section would be v = pi r^2 (delta x)
Also I'm having trouble finding the volume of the region enclosed by y = (2-x)(2+x), y = 3x, and the y- axis when rotated around the x - axis. It's hard to even picture what the figure will be like, much harder to find the volume. Please point me in the right direction! Thanks!
You seem to have the first part, but don't forget the limits of integration.
[tex]\pi\int_{-1}^{1}(x+2) dx[/tex]
For the second part, one thing that jumped out at me was:
[tex]y=(2-x)(2+x)=2^2-x^2=4-x^2[/tex]
is a parabola that opens downward, so it will hit the line
[tex]y=3x[/tex] in two (or zero) places.
So, let's look for intersections by solving:
Subtract
[tex]y=3x[/tex]
from
[tex]y=x^2-4[/tex]
to get
[tex]0=x^2-3x-4[/tex]
so we can use the quadratic formula
[tex]x=\frac{3\pm\sqrt{9-4(1)(-4)}}{2}=\frac{3 \pm 5}{2}[/tex]
That tells us that the functions intersect where [itex]x=-1[/itex] and where [itex]x=4[/itex]. Those will be the limits of integration. A quick check, say at [itex]x=0[/itex] confirms that [itex]4-x^2 > 3x[/itex] in the region.
So, to calculate the volume, you can (equivalently) calculate the volume from [tex]y=4-x^2[/tex]
on and then subtract the volume from
[tex]y=3x[/tex]
on the region.
Or you can integrate using annuli (annuluses?) instead of disks.
So, for the first one, the answer would be 4pi, correct?
For the second one, I thought the 2 functions interesected at (1,3), so I said the volume was pi times integral (with boundaries of 0 and 1) of [(4-x^2) -(3x)] dx since it has to be subracted. But I think I need to find the integral of r^2 times delta x, so would i have to square (4-x^2) and make it (16-x^4) then subtract 3x (or would it be 9x^2)? Thanks
