What Calculations Determine When Two Accelerating Objects Cross Paths?
  • Thread starter Thread starter rdn98
    Accelerating
The discussion revolves around the calculations necessary to determine when two accelerating objects cross paths. The first object starts with an initial velocity of 4 m/s and a constant acceleration of -17 m/s². Key equations used include v = v0 + at and x - x0 = (v0)t + (0.5)(a)t². The analysis reveals that the second object, moving at a constant speed of 4 m/s, will never cross paths with the first object after it comes to a stop and begins to reverse direction.
  • Understanding of kinematic equations for uniformly accelerated motion
  • Familiarity with quadratic equations and their solutions
  • Knowledge of relative motion concepts
  • Basic algebra for solving equations
  • Study kinematic equations in detail, focusing on applications in physics
  • Learn how to solve quadratic equations and their implications in motion problems
  • Explore relative motion and its applications in real-world scenarios
  • Investigate the effects of varying initial velocities on motion trajectories
Students studying physics, particularly those focusing on kinematics, as well as educators looking for examples of motion problems involving acceleration and relative velocity.
rdn98
Here is the problem from one of my online homework site. :-(
An object starts at time t = 0 with a velocity of v0 = +4 m/s and undergoes a constant acceleration of a = -17 m/s2.
There's five small parts to this problem but I got 4/5 done. I'll post them anyway to give you guys a clearer picture of what's happening here.
a) At what time does the speed of the object reach zero?
I used the equation v=vo+at. and I got the correct answer of t1=.235 seconds.Ok, that was easy.
b) How far from its starting (t = 0) position is the object at time t1?
This one I used the equation x-x0=(v0)t+(.5)(a)t^2
where x0=0, t=.235, a=-17
Answer I got was D=470 meters. Ok, that was easy too.
c) At what time does the object again pass through the starting (t = 0) position?
This I wasn't sure about. I figured if it took .235 seconds to reach a velocity of 0, then another .235 seconds would make it zero again. I typed in the answer .470 seconds. It's right, but I would like to know if this is the right reasoning, or is there another mathematical way of getting the correct answer?
d) If the object had initially been moving twice as fast (8 m/s), how far would it have gone before its velocity reached zero?
This I did the same thing with problem 1 and two, but used a different velocity number. The answer is 1.88m.
Now, this is where I get stuck...
e) Suppose a second object begins moving with a constant speed of v = 4 m/s in the same direction from the same location at the same time as the object in part (d). At what time do the paths of these two objects once again cross?
I know I have to derive equations which describe the x-position of both objects and set these equal to each other and solve for time. But I don't know how to derive the equations. I tried setting up two equations equal to each other, but the time I get is 0, which is wrong. Any ideas?
Although your answer to (a) is "correct", I would prefer the exact answer "4/17" to "0.235".
The "clean" way to do (c) is to note that, since the initial position was at 0, x=(v0)t+(.5)(a)t^2 (as you have) and then determine when x= 0 by setting (v0)t+(.5)(a)t^2= 0 and solving for t. That's a quadratic and has two solutions. Since it factors as
t( v0+ (.5)at)= 0, one obvious solutions is t= 0 (it was at 0 when t=0) and the other is t= -v0/(.5a): the second time it is at 0.
e) shouldn't be hard. You know the general equation (you used it before) x- x0= (v0)t+ (.5)(a)t^2. In the previous problems, you had an object that started at x0= 0 with v0= 4 and a= -17 so
x= 4t- (17/2)t^2. The new object starts with x0= 0, v0= 0 and a= 0 (because it has CONSTANT speed) so for it x= 4t. You are asked when the two "paths cross". Since they are moving in a straight line, I assume that means "are at the same place at the same time". Do exactly what you said: set the equations for x equal to one another.
Since the two objects are to have the same x for the same t,
x= 4t- (17/2) t^2= 4t.
That's what you did, right? And you canceled the 4t terms to get
-(17/2) t^2= 0 which has only the solution t=0, right?
Okay- have the courage of your convictions and answer "the two objects are NEVER in the same place at the same time again!"
Think of two cars driving east at the same speed. One continues east at constant speed, the other slows steadily, comes to a stop, and then goes in reverse, going west. It gets left far behind by the first car.
I think e) is referred to d) part in which the car has v0=8 m/s.
The answer is obviously 32/17 m.
  • · Replies 19 ·
