What Happens When Negative Numbers Are Used in Mod Operations?
  • Context: High School
  • Thread starter Thread starter baby_1
The discussion revolves around the behavior of the modulus operation when applied to negative numbers, specifically exploring the case of -10 mod 27. Participants examine the mathematical definition of modulus and its interpretation in both mathematical and programming contexts.
  • Some participants explain that the modulus operation can be viewed as a relation rather than just an operator, noting that a mod-n statement returns a true or false value based on divisibility.
  • One participant suggests that the convention is to find a unique number x such that a ≡ x (mod n) where x is non-negative and less than n.
  • A specific example is discussed where -10 mod 27 is proposed to equal 17, based on the reasoning that -10 - 17 is divisible by 27 and 17 is within the required range.
  • Another participant emphasizes the equivalence of a=b mod c to the condition that c divides (b-a), adding a technical nuance to the discussion.
  • Participants express gratitude towards each other for their contributions, indicating a collaborative atmosphere.
While there is a shared understanding of the modulus operation's definition, the application to negative numbers appears to be a point of exploration rather than consensus, with different interpretations and explanations presented.
The discussion includes various interpretations of the modulus operation, particularly in relation to negative numbers, and highlights the importance of defining the range of the result. There are also references to both mathematical and programming perspectives that may lead to different conclusions.
This discussion may be useful for individuals interested in mathematics, programming, or those seeking clarification on the modulus operation, particularly in the context of negative numbers.
baby_1
Hello
i know that it shows Remaining for example
5 mod 3=2
1 mod 3=1
but if i select negative number what does it do?
example:
-10 mod 27 =?
Thanks
Mathematics news on Phys.org
baby_1 said:
Hello
5 mod 3=2
1 mod 3=1
example:
-10 mod 27 =?
Thanks
In math, mod is defined as a relation, rather than an operator. So we would say
5 [itex]\equiv[/itex] 2 (mod 3)
and
1 [itex]\equiv[/itex] 1 (mod 3)
where the [itex]\equiv[/itex] in this context is pronounced "is congruent to."
In other words a mod-n statement returns "true" or "false" when applied to pairs of numbers. The general rule is that
a [itex]\equiv[/itex] b (mod n) if the number n divides a - b.
Now a lot of people come to mod from programming languages, where mod is not a relation, but is rather an operator, meaning that it returns a single value. That's the usage you've written, so we say
5 mod 3=2
and so forth.
But even though 5 [itex]\equiv[/itex] 2 (mod 3), it's also true that 5 [itex]\equiv[/itex] 47 (mod 3), right? Both 47 and 5 give the same remainder when divided by 3. [That's equivalent to the definition I gave earlier; but you should actually convince yourself of that]
So if someone asks us what is 5 mod 3, what should the answer be? The convention is that we take the unique number x such that 5 [itex]\equiv[/itex] x (mod 3) and x is greater than or equal to 0, but less than 3.
With that background, what is the answer to -10 mod 27 = ?
Well, let's find x such that -10 [itex]\equiv[/itex] = x (mod 27), and x is between 0 and 26 inclusive. A moment's thought will convince you that x = 17 is the right answer here. So
-10 mod 27 = 17
That's because
a) -10 - 17 is divisible by 27; and
b) 17 is the unique number with that property that's also between 0 and 26, inclusive.
That's a long answer but it's everything you need to know to make sense of this kind of problem.
baby_1 said:
Hello
5 mod 3=2
1 mod 3=1
example:
-10 mod 27 =?
Thanks
Maybe a quick way of answering is a=b mod c is equivalent to : c|(b-a) , or, the
remainder of dividing a by c is b*. And complement it with Stevel27's answer.
* This is a technical point, since we usually choose the remainder to be within
a given range, but we can add multiples.
Thanks Dear SteveL27 & Bacle2
you are my best teacher that dedicate your time to telling me the right answer.
Thanks again
Thanks, but I did only a minimal part.
That's how I like it, Stevel27 does 99%+ of the work and we split the credit in half ;) .
I don't mind. I got 99% of the cash reward :-)
  • · Replies 29 ·
42K
