| New Reply |
30º above the horizontal with initial velocity problem |
Share Thread |
| Sep4-12, 02:38 PM | #1 |
A basketball player throws a ball at an angle of 30º above the horizontal. If the ball in has an initial velocity of 29.4 m/s, how far does it travel? 2. Relevant equations Vyf^2 = Vyi^2 + 2(Ay)(Dy) solve for Dy and get [Vyf^2 - (Vyi^2)] / (2(Ay)) = Dy 3. The attempt at a solution 0 - (29.4sin30)^2 / (2(-9.8)) = 11.025 29.4sin30 = 14.7 and then 14.7^2 = 216.09 and then 0 - 216.09 is -216.09/(2(-9.8)) = 11.025 |
| Sep4-12, 02:42 PM | #2 |
'how far does it travel' refers to a horizontal distance. First start by computing the time of flight.
| Sep4-12, 02:48 PM | #3 |
Okay so my new attempt is Vyf = Vyi + AyT
0 = 29.4 + -9.8t -29.4 = -9.8t 3 = t So my time is 3, now just don't know what equation to use |
| Sep4-12, 02:52 PM | #4 |
| Sep4-12, 02:54 PM | #5 |
Sorry that this is going to seem hopeless but I just started taking an online course... What exactly does Vyi stand for? I thought it was the initial velocity in the vertical direction but that must be wrong
| Sep4-12, 02:59 PM | #6 |
| Sep4-12, 03:04 PM | #7 |
Ooh sinθ is with it. So vyi = 14.7, which would mean t = 1.5
After that I tried using the dx = vx * t equation but that didn't work. What is the formula to solve for horizontal distance? |
| Sep4-12, 03:11 PM | #8 |
What you have found is the time to the apex of the trajectory. To find the time for the whole flight, either multiply your time by 2, (valid because of symmetry of flight and constant horizontal component of velocity) or redo the whole calculation using the condition, [tex] v_{yi}\hat{y} = -v_{yf}\hat{y} [/tex]
Edit: To clarify, the vertical component of final velocity (when the ball lands back to the ground) is equal in magnitude but opposite in direction to the vertical component of initial velocity. |
| New Reply |
| Tags |
| projectile motion 2d |
Similar discussions for: 30º above the horizontal with initial velocity problem
| Initial Vertical Velocity of a non - horizontal projectile (trebuchet) | Introductory Physics Homework | 0 | ||
| Horizontal projectile, NOT GIVEN INITIAL VELOCITY | Introductory Physics Homework | 11 | ||
| Baseball's Initial Velocity Problem | Introductory Physics Homework | 3 | ||
| Horizontal motion problem involving coefficient of friction and initial velocity. | Introductory Physics Homework | 2 | ||
| Why does drop time remain constant regardless of initial horizontal velocity? | General Physics | 5 | ||
