| New Reply |
Frame for lighter-than-air aircraft. |
Share Thread | Thread Tools |
| Sep6-12, 06:33 PM | #1 |
Hello everyone.
I have been trying to think of some practical and cheap airship designs. I have done some calculating, and if you were to have an airship's envelope in a cylindrical shape that is 300' long and 75' in diameter, it would be able to lift approximately around 45 tons if filled with hydrogen as a lifting gas (Not factoring in the atmospheric affects on the hydrogen's density) (Not including the weight of the envelope nor gonadal). Question: If you were to have an envelope of this design, would it require a frame, and if so, what would be the best material to make it out of (Factoring in the weight and cost of said material)? *Note* I do not actually intend on constructing a lighter-than-air aircraft. This is just an interest of mine. |
| Sep7-12, 03:43 PM | #2 |
Check out blimps/Hindenburg/hydrogen.
Are you proposing something fundamentally different? |
| Sep7-12, 05:57 PM | #3 |
Any vessel that relies on internal pressure for rigidity will try to turn itself into a sphere. How do you stop the flat ends becoming domed? Anyway you want them domed so it goes through the air more easily. See also what jehake12 said.
| Sep7-12, 06:36 PM | #4 |
Thank you for the replies!
I have actually done some debugging to my design, it would appear that a semi-rigid frame would be the logical choice, holding the general shape of the envelope and allowing the gas pressure to do the rest. I would plan on crafting the frame of aluminum rods. My only concern is that if I made the frame of aluminum rods, it would weight the craft down too much, but if I use hollowed out aluminum piping, it would lose it's shape. Do any of you have any thoughts on a possible solution? |
| New Reply |
| Thread Tools | |
Similar Threads for: Frame for lighter-than-air aircraft.
| Rotating cylinder on x'-axis in S' frame. Find twist per unit length in S frame | Advanced Physics Homework | 1 | ||
| Workings of Aircraft/Electronics of Aircraft | Aerospace Engineering | 0 | ||
| Z lighter than W? | High Energy, Nuclear, Particle Physics | 0 | ||
| Always-on cigar lighter? | Electrical Engineering | 15 | ||
| On a lighter note... | General Discussion | 25 | ||
