Force Experienced by an Electron in an Electric Field
An electron placed in an electric field of strength 300 N/C experiences a force calculated using the formula F = qE, where q is the charge of the electron (1.6 x 10^-19 C). The correct force is 4.8 x 10^-17 N, which is not among the provided options. For a particle with a mass of 0.005 kg and a charge of +4.0 µC in an electric field opposing gravity, the field strength required to balance the weight is calculated using E = mg/q, yielding a value of 1.225 x 10^4 N/C, which also does not match the given choices. The discussion highlights the importance of correctly applying fundamental physics equations to solve problems.
  • Understanding of electric fields and forces
  • Familiarity with the equation F = qE
  • Knowledge of mass, weight, and gravitational force
  • Basic proficiency in unit conversions (e.g., microcoulombs to coulombs)
  • Review the principles of electrostatics and electric fields
  • Study the derivation and application of the equation F = qE
  • Learn about balancing forces in electric fields and gravitational fields
  • Explore unit conversions and their importance in physics calculations
Students studying physics, educators teaching electrostatics, and anyone interested in understanding the interaction between electric fields and charged particles.
Soaring Crane
An electron is placed in an electric field of strength 300 N/C. What is the magnitude of the force the electron experiences?
1.6x10^13 N
2.4x10^13 N
3.2x10^14 N
4.8x10^14 N
6.4x10^14 N
A particle of mass 0.005 kg is given a charge of +4.0 µC and is placed in an electrical field that is directed antiparallel to the Earth's gravitational field. What is the field strength, expressed in N/C, if it balances the weight of the particle?
1.6 x10^6
2.4 x10^6
3.2 x10^6
4.4 x10^6
4.7 x10^6
Wen I tried to do these questions, I did not even come close to the figure in bold. I thought F = Eq or F = mg/q would be sufficient enough, but I guess not. Can anyone explain how to arrive at each answer?
Thanks.
F = Eq is the correct equation to use for the first part, but all those answers listed are wrong.
q is the charge of an electron = 1.6 * 10^-19 C,
Just look at the exponents. You would have to have an E in the order of 10^33 N/C in order to come anywhere near those numbers. Are you sure you copied the question correctly?
For the second, I think you mean E = mg/q not F = mg/q. Again, all the choices are wrong? Where did you get these questions?
1.6x10^13 N
2.4x10^13 N
3.2x10^14 N
4.8x10^14 N
6.4x10^14 N
None of these answers are even close to being right. The force is qE. If E is 300 and q is 1.6e-19 Coulomb, qE = 4.8e-17 N.
1.6 x10^6
2.4 x10^6
3.2 x10^6
4.4 x10^6
4.7 x10^6
Again: F = qE, but in this case F also = mg, so qE = mg; E = mg/q
Plugging in the numbers, E = 5e-3*9.8/4e-6 = 1.225 e4 N/C Again none of the answers fit.
AM
