How Does Friction Affect the Motion of a Spring-Attached Block?
The discussion focuses on calculating the effects of friction on the motion of a spring-attached block with a mass of 10 kg and a spring constant of 1850 N/m. The coefficient of sliding friction is 0.25, and the block is initially pulled back 11 cm. The key equation derived is -ΔPE = ΔKE + W(friction), where W(friction) represents the work done against friction. The relationship ΔK + ΔU = -fd is also established, indicating that the change in total energy is equal to the work done on the system, factoring in frictional losses.
  • Understanding of Hooke's Law and spring constants
  • Knowledge of kinetic and potential energy concepts
  • Familiarity with friction force calculations
  • Basic principles of energy conservation in mechanical systems
  • Study the calculation of work done against friction in mechanical systems
  • Learn about energy conservation principles in oscillatory motion
  • Explore advanced topics in dynamics involving friction and springs
  • Investigate the effects of varying coefficients of friction on motion
Physics students, mechanical engineers, and anyone interested in understanding the dynamics of spring systems with frictional forces.
Tycho
a block of mass 10kg is attached to a spring with a constant of 1850 N/m. the coefficient of sliding friction between the block and the surface is .25
the block is pulled back 11 cm to the right and released.
the question asks the speed at different points, and how far the distance after equilibrium it travels.
THe problem i have is this... i am fine on all of this except for how to figure the friction into the equation? i know the velocity neglecting friction, and i know the force of friction acting on the box. i need something to put the two together. can someone please lend me a small hand?
The stretched spring has a certain PE. If there were no friction, as the spring contracted [itex]-\Delta \texrm(PE) = \Delta \texrm(KE)[/itex]. But with friction, some of that PE is transformed to heat via work done against friction. So: [itex]-\Delta \texrm(PE) = \Delta \texrm(KE) + W_\texrm{(friction)}[/itex]. What's the work done against friction?
How about considering the energy?
[tex]\Delta K + \Delta U = -fd[/tex]
where f is the friction force, d is the distance travelled, and K and U are kinetic and potential energy, respectively. This is a statement that says the change in total energy of the system is equal to the work done on the system (the work done on the system in this case is negative (frictional loss)).
Try take it from there; we can help more if you need it.
  • · Replies 27 ·
11K
