New Reply
Flow Rate in Water Clock
Share Thread Thread Tools
Sep8-12, 11:42 PM   #1
Hi guys,
A few friends and myself are having some trouble determining how to go about solving this problem for our engineering class.
"An emptying tank in which the water level drops at a constant rate in time can be used as a water clock. Consider a tank where the drainage volumetric flow rate is proportional to h^(1/2), where h is the liquid height. What must be the shape of the tank so that the draining vessel may be used as a water clock?"
The shape of the water clock isn't given, but we all know it's a conical water clock, where the flow rate isn't constant, but dh/dt is, which allows for a linear scale to be read from. The goal is to prove that it the volume is a conical shaped water clock or the flow rate is equivalent to what was stated in the problem. We can assume it's a conical water clock to prove that it equates to the flow rate.
2. Relevant equations
There weren't any equations given, but this is the most generic form used for this engineering type problem.
d/dt(p*V) = p*Qe
3. The attempt at a solution
We've attempted multiple different ways, but it ultimately ended up in the same situation.
I started with
dV(h) = A*dh; A = pi*[r(h)]^2
r(h)=(R*h)/L, where R is the radius of the top of the cone, and L is the height of the entire water clock.
V(h) = (pi*R^2*h^3)/(3L^2)
Took the derivative with respect to time and set it equal to the flow rate
dV/dt = (pi*R^2*h^2/L^2)*dh/dt = k*h^(1/2), where k is a proportionality constant.
This is where we continuously get stuck at, because we see no way to get an h^(1/2) from anywhere.
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> PNNL-developed injection molding process recognized with emerging technologies award
>> How soon could car seats enter the 3-D comfort zone?
>> NASA: Austin, calling Austin. 3-D pizzas to go
Sep10-12, 02:34 PM   #2
Recognitions:
Gold Membership Gold Member
You're on the right track, I think what you may be missing is the relation of outflow rate (dV/dt) with column height. This is probably most easily adapted through the use of Torricelli's Principle which is basically a simplified Bernoulli relation showing the flow speed of an orifice can be balanced with the potential energy in the water column. In other words, ignoring effiency concerns the speed water exits an orifice can be approximated as v = sqrt(2*g*h).
You will probably also appreicate this PDF which might help you clarify the calculation you're trying to achieve: The Clepsydra
New Reply
Thread Tools
Similar Threads for: Flow Rate in Water Clock
Thread Forum Replies
Calculating the flow rate of water from a tap and on the surface of a water tank Introductory Physics Homework 7
Rate of Water Flow help. General Physics 1
Rate of Flow of water out of can Calculus & Beyond Homework 4
Water flow rate Introductory Physics Homework 2
HELP! relationship between rate of flow of water and height of water column Introductory Physics Homework 1
