Calculating Constants in indefinite integral with 2 values for f.
The problem involves finding a function f(x) such that its second derivative f''(x) equals 1/x², with the conditions that f(1) = 0 and f(e) = 0. The discussion centers around the integration process and the determination of constants based on the given conditions.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the integration of f''(x) to find f'(x) and subsequently f(x), while attempting to determine the constants c and C that satisfy both boundary conditions. There is a focus on evaluating f(1) and f(e) in terms of these constants.
Some participants have provided guidance on how to express the function in terms of the constants and have noted that two equations can be derived from the boundary conditions to solve for the constants. There is an acknowledgment of the challenge in determining both constants from the given values of the function.
Participants note that the problem involves two constants and two conditions, which raises questions about the sufficiency of the information provided to uniquely determine the constants. There is also mention of the nature of the differential equation and the typical requirements for solving such equations.
tainted
Find the function f(x) such that [itex]f''(x) = \frac{1}{x^2}[/itex], [itex]f(1) = 0[/itex] and [itex]f(e) = 0[/itex]
[itex]\int f''(x)\,dx = f'(x) + c[/itex]
[itex]\int f'(x)\,dx = f(x) + cx + C[/itex]
[itex]f''(x)= \frac{1}{x^2}[/itex]
[itex]f'(x)= \int \frac{1}{x^2}\,dx = \frac{-1}{x} + c[/itex]
[itex]f(x) = -\int \frac{1}{x} + c\,dx = -ln(x) + cx + C[/itex]
My problem is that I can get the constants to satisfy one of those requirements in the original problem, but I am having trouble getting it to satisfy both.
Thanks in advance
Show some work? Might be able to find the issue. With only two data points and two constants, there shouldn't be any big issue setting both.
That is my work. That's what I've had for over an hour /facepalm
I've tried guessing some constants, but nothing has worked. I don't know how to get the constants to fit both those statements
All right then. What are [itex]f(1),f(e)[/itex] in terms of these constants?
I really have no clue. In terms of what constants? I haven't seen anything like this problem before. I have seen plenty where [itex]f'(e)=0[/itex] and [itex]f(1) = 0[/itex]or the likes, but I haven't seen them where both value were just for [itex]f[/itex]
itex, not itext.
In terms of the constants [itex]c, C[/itex]. You wrote [itex]f(x)[/itex] in the first post. Even though you don't know the values of [itex]c,C[/itex], you should be able to evaluate the function and get an expression in terms of these constants at [itex]x=1,e[/itex].
Alright thanks. I think that got me going in the right direction.
[itex]f(x) = -ln(x) + cx + C[/itex]
[itex]f(1) =-ln(1) + 1*c + C = 0[/itex]
[itex]f(e) = -ln(e) + e*c + C = 0[/itex]
[itex]-ln(1) + 1*c + C = -ln(e) + e*c + C[/itex]
[itex]-0 + c + C = -1 + e*c + C[/itex]
[itex]c = e*c - 1[/itex]
[itex]c + 1 = e*c[/itex]
[itex]1 = e*c - c[/itex]
[itex]1 = c(e-1)[/itex]
[itex]\frac{1}{e-1} = c[/itex]Does that look correct on evaluating for [itex]c[/itex] ?
Yeah, I think that's correct. You should be able to substitute in and find [itex]C[/itex] at this point. In general, as you can see, if you have an Nth order differential equation, you only need N pieces of information in order to determine all the integration constants. They can be values of derivatives or values of the function itself at any arbitrary points.
Using that value for [itex]c[/itex], I did the following.
[itex]f(x) = -ln(x) + \frac{1}{e-1} * x + C[/itex]
[itex]f(x) = -ln(x) + \frac{x}{e-1} + C[/itex]
[itex]f(1) = -ln(1) + \frac{1}{e-1} + C = 0[/itex]
[itex]f(1) = -0 + \frac{1}{e-1} + C = 0[/itex]
[itex]C = \frac{-1}{e-1}[/itex]
That would make my final answer
[itex]f(x) = -ln(x) + \frac{x}{e-1} - \frac{1}{e-1}[/itex]
I tested it, and it appeared to work
Thanks a lot man. At first I was trying to figure out what you meant, but once I did, I was able to get it. I hadn't realized that you could have only 2 values of the function to determine both the constants
Thank you
Yeah, you just end up with two equations, two unknowns in a linear system. It's a piece of cake once you've seen it once or twice. Just making the leap to getting there is the only hard part.
  • · Replies 105 ·
13K
  • · Replies 21 ·
