Division of Chi Squared Random Variables
The division of two independent chi-squared random variables, X and Y, each with n degrees of freedom, does not yield a standard distribution of 1. Instead, the ratio X/Y follows an F-distribution, specifically derived from the properties of chi-squared distributions. It is crucial to understand that having the same degrees of freedom does not imply that X and Y are equal or follow the same distribution. For a comprehensive understanding, one should refer to the derivation of the F-distribution.
  • Understanding of chi-squared distributions
  • Knowledge of F-distribution properties
  • Familiarity with statistical independence
  • Basic concepts of probability density functions (PDFs)
  • Study the derivation of the F-distribution from chi-squared distributions
  • Explore the properties of independent random variables in statistics
  • Learn about the applications of F-distribution in hypothesis testing
  • Investigate the implications of variable independence in statistical analysis
Statisticians, data analysts, and students studying probability theory who seek to deepen their understanding of chi-squared and F-distributions.
jojay99
Hey guys,
I have a quick question. Suppose X is a chi squared random variable with n degrees of freedom and Y is another independent chi squared random variable with n degrees of freedom.
Is X/Y ~ 1 ?
Intuitively, it makes sense to me but I'm not too sure.
Hey jojay99 and welcome to the forums.
If X != Y the answer is an emphatic no. You can't just assume that X = Y just because both have the same degree of freedom: if they are two distinct random variables then they will have some distribution.
The result you should look at is the derivation of the F-distribution:
http://en.wikipedia.org/wiki/F-distribution
Any derivation of the F-distribution will tell you how the distribution for a ratio of chi-square distributions (with terms for the degrees which are constants) is derived.
Remember that if you have two distributions you need to check whether the two variables correspond to the same process and not the same variable definition or PDF.
Another thing to think about: is X + Y = 2X? How about X + Y = 2Y? Even if it's not a random variable, just think a normal variable and consider those questions.
