How do I evaluate <x^2> for a Gaussian function?
  • Thread starter Thread starter BucketOfFish
    Function Gaussian
The discussion revolves around evaluating the expectation value of \( x^2 \) for a Gaussian function, specifically the integral \(\int^{\infty}_{-\infty} e^{-x^2}x^2dx\). Participants explore various approaches to this integral within the context of Gaussian distributions.
  • The original poster attempts integration by parts and u-substitution but encounters difficulties. Some participants suggest considering the derivative of a related integral with respect to a parameter, while others question the correctness of signs in the calculations.
Participants are actively engaging with the problem, providing hints and corrections. There is acknowledgment of errors in the original calculations, and some guidance has been offered regarding the differentiation of integrals. However, there is no explicit consensus on the final approach or outcome.
There is a discussion about the implications of sign errors in the context of the integral, as well as the independence of variables involved in the differentiation process. The original poster's attempts reflect the constraints of homework rules and the need for careful mathematical reasoning.
BucketOfFish
For some Gaussian distribution, let's say [itex]e^{-x^2}[/itex] times a constant, I want to find the expectation value of [itex]x^2[/itex]. In other words, I want to evaluate:
[tex]\int^{\infty}_{-\infty} e^{-x^2}x^2dx[/tex]
Integration by parts:
[tex]\int udv = uv - \int vdu[/tex]
I tried a few things actually, but none of them got anywhere. One of the routes I attempted was u-substitution followed by integration by parts. First, since the function is even, you set it equal to:
[tex]2\int^{\infty}_{0} e^{-x^2}x^2dx[/tex]
Letting [itex]a = x^2, da = 2xdx[/itex], we get:
[tex]\int^{\infty}_{0} e^{-a}\sqrt{a}da[/tex]
Then, letting [itex]u = \sqrt{a}, dv = e^{-a}da, du = \frac{1}{2\sqrt{a}}da, v = -e^{-a}[/itex]:
[tex]\int e^{-a}\sqrt{a}da = -\sqrt{a}e^{-a} + \int e^{-a}\frac{1}{2\sqrt{a}}da[/tex]
And here I get stuck. Anybody have hints?
Think about [itex]\int^{\infty}_{-\infty} e^{- a x^2} dx[/itex]. You can work that out, right? Now what is d/da of that when a=1?
Nice hint.
Ok, so I think I've got it. Basically, you take:
[tex]\int^{\infty}_{-\infty} -\frac{de^{-ax^2}}{da}dx[/tex]
Then since x and a are independent of each other, you can bring the d/da outside the integral:
[tex]\frac{d}{da}\int^{-\infty}_{\infty} e^{-ax^2}dx[/tex]
Then you do that integral to get [itex]-\sqrt{\pi/a}[/itex], and after taking the derivative with respect to a, you get [itex]\frac{\sqrt{\pi}a^{-3/2}}{2}[/itex]. Plugging in a=1, you end up with [itex]\frac{\sqrt{\pi}}{2}[/itex] for your final answer.
I didn't offend any mathematicians with egregiously bad calculus, did I?
Maybe. But even physicists would be offended because the sign is obviously wrong. x^2*exp(-x^2) is a positive function. How can its integral be negative?
Yep, I realized my terrible error and fixed it. Does it look alright now?
The answer is right. I'm not sure you've put the sign correction in the right place everywhere. But I'm sure you can fix it.
  • · Replies 105 ·
13K
  • · Replies 21 ·
