New Reply
question about lifting up 90 Kilogram weight
Share Thread Thread Tools
Sep13-12, 09:49 PM   #1
I am trying to build a helicopter. please help me.
I want to know how much RPM and size of blade needed to lift 90KG of weight.
I am planning not to use tail rotators, but I have a solution for this.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Sep13-12, 11:12 PM   #2
Is this a troll or are you serious?
Sep13-12, 11:25 PM   #3
Yes man!!
did I asked anything wrong?? is it not possible.
Actually I am have not much knowledge in Physics, cause i am IT Engineer.
Due to my interest in science, I made a small helicopter. And it works.
Now i want to make a small helicopter which will lift a man.
Any suggestion will help, I will show you project design if you want.
Sep13-12, 11:57 PM   #4
The first helicopter was a chair with a rotary blade attached to the top of it. It did not go well. There are a few things they did not consider. The first is that this setup will tip over due to the change in pressure distribution the blade creates, and the chair will also rotate, although not as fast as the blade. This is considering your design is structually sound and you have enough power to get it off the ground.
The solutions were a blade with hinges that compensate for the uneven pressure distribution and a tail rotor to counteract the base rotation.
To answer your question though, it's probably not a good idea.
Sep15-12, 05:06 AM   #5
Thanks Vadar2012
I am planning to use coaxial propellers.
Can you suggest me any Electric MOTOR and Lithium battery to use in my project
Sep15-12, 05:53 AM   #6
Quote by tovolt View Post
Thanks Vadar2012
Helicopters of the type exist. See this article. I don't think any existing lithium battery stores enough energy to lift you for more than a short time. You will probably need a fuel-powered engine.
Sep15-12, 06:17 AM   #7
Check out this link. I think this is what you are aiming at.
Sep15-12, 09:29 AM   #8
phyzguy thanks,
I will inform you more about the project after I start work on it.
Can you tell me any site where I can buy robotics and electric motors??
Sep15-12, 09:37 AM   #9
It is very hard and challenging task to make a coaxial rotor Head.
for rotating helicopter body In coaxial rotor I need to slow down a propeller,
is it right????
New Reply
Tags
helicopter, lifting
Thread Tools
Similar Threads for: question about lifting up 90 Kilogram weight
Thread Forum Replies
a weight lifting question General Physics 11
Weight lifting General Discussion 51
Laws of Motion in weight lifting General Physics 3
Lifting Weight VS Pushing a Scale General Physics 24
Does Sit ups/ weight lifting reduce growth? General Discussion 1
