From Uranium isotope to thorium isotope
  • Thread starter Thread starter Orion78
    Isotope Uranium
The conversion of Uranium-238 (U-238) to Thorium-234 (Th-234) involves specific decay processes. Electron capture occurs zero times, while alpha decay occurs once, resulting in a mass number of 234 and an atomic number of 90. The discussion clarifies that the question does not allow for beta decay, which would have provided alternative answers. The consensus is that the phrasing of "1 times" should be disregarded for clarity.
  • Understanding of nuclear decay processes, specifically electron capture and alpha decay
  • Familiarity with isotopes and their notation (e.g., Uranium-238, Thorium-234)
  • Knowledge of atomic mass and atomic number concepts
  • Basic grasp of beta decay and its implications in nuclear reactions
  • Research the mechanics of electron capture in nuclear physics
  • Study the process of alpha decay and its effects on isotopes
  • Explore the role of beta decay in nuclear transformations
  • Investigate the stability of isotopes and their decay pathways
Students and professionals in nuclear physics, educators teaching nuclear chemistry, and anyone interested in the processes of radioactive decay and isotope conversion.
Orion78
I need to complete the following sentence. If I think that electron capture or alpha decay does not occur in my decay process, I have to type a '0' (zero) in the appropriate box:
Converting an atom of the isotope Uranium (238-92) into an atom of thorium can be accomplished if an electron capture process occurs___times and an alpha decay occurs ___times. The resulting isotope has a mass number___ and an atomic number___ .
Initially I thought the right answers were: zero, one, 234, 90. But after I realized that I cannot say one times because times is plural. Is it only one right answer of there are different options? The resulting isotope has definitely a atomic number of 90, but I am not sure about the rest. Thanks for your help
Your answers are quite correct. There is no other answer because there is no allowance for a beta decay, and electron capture processes would usually only happen with a proton-rich isotope (mass number lower than those of the most stable or abundant isotopes of the element).
If beta decays were allowed for, then "beta (-) decay occurs 2 times and alpha decay occurs 2 times ... 90 ... 230 ..." might be an alternative answer, but the question is simply not worded that way.
I think you should ignore the slightly ungrammatical "1 times" in a question like this.
  • · Replies 36 ·
