New Reply
Another question about negative work
Share Thread Thread Tools
Sep15-12, 05:49 PM   #1
Unfortunately I still have not completely grasped the idea of negative work. I appreciate all the help in understanding this concept!
Suppose that you lift a block of mass M an upwards distance of D. The force you applied on the block is a constant F directed parallel to the displacement of the block. Then by the definition of work, you did work equal to FD on the block. This quantity is positive. I think we can all agree on that.
What about the work that the block does on you?
Argument 1:
Since you applied an upward force F on the block, the block exerts a downward force F on you. But your displacement relative to the block is also downwards, and it has magnitude D.
Thus, the work that the block does on you is FD and this quantity is positive.
Argument 2:
You worked on the block and transferred kinetic energy to it. You lost energy, the block gained energy. Since you lost energy, the block did "negative work" on you. This is an immediate consequence of the work-kinetic energy theorem. The magnitude of this work is FD but it is a negative quantity because the block gains energy and you lose energy.
Which of these arguments is valid? Why is the other argument invalid? Hopefully I am not the only one having trouble to understand this...
Thanks!
BiP
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Sep15-12, 08:33 PM   #2
Quote by Bipolarity View Post
Argument 1:
Displacement is measured relative to a coordinate system (aka frame of reference).
For a fixed frame of reference, the work that you do on the block is equal and opposite to the work that the block does on you.
For contact forces, this is an immediate consequence of Newton's third law.
Argument 2:
Bingo. This latter argument is correct.
Sep15-12, 08:36 PM   #3
Ok so the block does negative work on you and the magnitude of that work is FD.
So the force it applies on you must be opposite direction to your displacement. The force it applies to you is obviously directed downwards, right? Which means your displacement must be upwards... but that is not correct?
BiP
Sep16-12, 12:32 AM   #4
The reason why argument 1 is invalid is because the displacement is not negative. The displacement for this situation is 0 because you do not move. You cannot say the displacement is negative because that would take you into another FoR where the box doesn't move. I think to reason negative work you have to find out what is responsible for the positive work on an object and subtract the energy it took to do that work from the source because of the conservation of energy.
Sep16-12, 10:05 AM   #5
Quote by salzrah View Post
I understand work in terms of kinetic energy, but the calculations must still be reconciled with the force-displacement definition of work.
If your displacement having moved the block is 0, then the work that the block does on you should also be 0. And yet, it is equal to -W.
BiP
New Reply
Thread Tools
Similar Threads for: Another question about negative work
Thread Forum Replies
Question about the significance of negative work Classical Physics 3
Negative and positive work - Question General Physics 3
The conservation of energy, why does it work? Negative work vs positive work Introductory Physics Homework 54
How can work be negative? General Physics 3
[Work and Energy] Work positive or negative? Introductory Physics Homework 3
