| New Reply |
Line integral setup |
Share Thread | Thread Tools |
| Sep15-12, 06:58 PM | #1 |
Line integral setup
A squirrel weighing 1.2 pounds climbed a cylindrical tree by following the helical path [itex]x = \cos{t}, y = \sin{t}, z = 4t, 0 \leq t \leq 8 \pi [/itex] (distance measured in feet) How much work did it do? 2. Relevant equations [itex]\int_{C} \vec{F} \cdot d\vec{r}[/itex] 3. The attempt at a solution I've defined a curve [itex]C[/itex] by the vector [itex]\vec{r}(t) = \cos{t} \vec{i} + \sin{t} \vec{j} + 4t \vec{k}[/itex], [itex]0 \leq t \leq 8 \pi[/itex] I'm not sure where to go from here. Specifically, I don't know how to use the weight of the squirrel. Every other problem I've worked on explicitly gave me a vector field to work with. I know the bounds of the integral will be from 0 to 8π, and that r'(t) will be used. Thanks in advance! |
| Sep15-12, 09:48 PM | #2 |
The squirrel's weight points straight down. Try ##\vec F = \langle 0,0,-1.2\rangle##. And remember the line integral gives the work done by the force. You should be able to check your answer by comparing the change in potential energy.
| Sep16-12, 01:50 AM | #3 |
Got it, thanks.
So I should get my answer with the following integral: [itex]W = \int^{8\pi}_{0} (0\vec{i} + 0\vec{j} - 1.2\vec{k}) \cdot (-\sin{t}\vec{i} + \cos{t}\vec{j} + 4\vec{k}) dt ?[/itex] This isn't for a physics course, and we haven't learned anything about potential energy. If the integral's setup is right, though, I can't take it from there. |
| Sep16-12, 02:32 AM | #4 |
Line integral setup
I'm not still new at line integrals so take this with a grain of salt.
| Sep16-12, 12:38 PM | #5 |
Sorry, I meant I can take it from there. Thanks though!
| New Reply |
| Thread Tools | |
Similar Threads for: Line integral setup
| Triple Integral Limits Setup Cartesian | Calculus & Beyond Homework | 3 | ||
| Double Integral Setup | Calculus & Beyond Homework | 8 | ||
| How to setup a LAN (via phone line)??? | Computing & Technology | 3 | ||
| How to setup an integral in spherical coordinates for the volume of p = 2 sin O(theta | Introductory Physics Homework | 3 | ||
| E&M line integral setup | Introductory Physics Homework | 2 | ||
