Finding the frequency of the combined motion
  • Thread starter Thread starter RockenNS42
    Frequency Motion
The discussion revolves around finding the frequency of the combined motion represented by the expression sin(12πt) + cos(12πt - π/4). Participants explore the relationship between the periods of the sine and cosine functions involved.
  • Participants discuss the periods of the sine and cosine functions, with attempts to apply trigonometric identities to simplify the expression. Questions arise regarding the relevance of the phase shift and how it affects the overall frequency.
Some participants have offered guidance on using trigonometric identities to combine the functions, while others express confusion about the implications of their calculations. Multiple interpretations of the problem are being explored, with no clear consensus yet on the correct approach.
There is mention of discrepancies between participants' calculations and the answer provided in a textbook, leading to further questioning of assumptions and methods used in the problem-solving process.
RockenNS42
Finding the frequency of the combined motion of the following
sin(12πt)+cos(12πt-π/4)
T=n2T2=T1n1
Ok so I found the periods be 1/6 for the sin function and 2/13 for the cosine
Any hints on what to do next? I really have no clue
the answer in 6.25/s
Think about fundamental trig identities.
which fundamental ones? like this one sin(θ)^2 + cos(θ)^2 = 1?
Im not quite sure I follow you on how this could help
Im getting my T from T=n2T2=T1n1
to be 2s so the f is .5/s, which is wrong
also the question is actually
sin(12πt)+cos(13πt-π/4)
Does it have to do withe the π/4 in the cos argument?
I was thinking of [tex]\sin(x)=\cos(\frac{\pi}{2}-x) [tex], so you can convert the cosine or sine term this way, so that you have two sine or two cosine functions. Then look to use the equation you mention. I think this is should give the right result[/tex][/tex]
If I do that I get
sin(12πt)+sin(13πt-3π/4)
But this doesn't change the angular velocity values, so it doesn't change the the period or frequency... or am I totally missing something here?
So now I'd say try this identity, [ itex ] \cos(\phi-\th)=\cos(\phi)\cos(\th)-\sin(\phi)sin(\th) [ /itex ]. Which has its sin counterpart, [ itex ] \sin(\phi-\th)=\sin(\phi)\cos(\th)+\cos(\phi)sin(\th) [ /itex ]. I think now you'll be able to write this as one sine or cosine function with a combined frequency
ok so
so I changed it too
cos(π/2-12πt)+cos(13πt-π/4)
and used that identity to get
[cos(13πt)cos(π/4)-sin(13πt)sin(π/4)] -[cos(π/2)cos(12πt)-sin(π/2)sin(12πt)]
which simplifies to
√2/2[cos(13πt)-sin(13πt)]-[cos(12πt)]
i really appropriate your help, but I am just not getting it, Ill have to go into see my prof I guess, thanks for sticking with me this far
Or simply,
T=n1*1/6=n2*2/13
where n1 and n2 are the lowest common value multiple of the individual periods.
Sorry for the long probably round about explanation.
klawlor419 said:
Or simply,
T=n1*1/6=n2*2/13
I did that part at the first and got n1=12 ans n2=13.
this gave a T of 2sec and a f of .5/sec
which totally makes sense to me but the back of my book says the answer is 6.25/sec
You can use this identity:
http://www.wolframalpha.com/input/?i=factor+sin+x+++sin+y
to get a product of two sin terms.
It will result a typical expression encountered when you study beats between two close frequencies.
The motion has a fast, 6.25 Hz component, modulated by a slow varying "amplitude" (0.25 Hz).
This link shows how to derive the identity, which gives the result 6.25Hz and .25Hz
http://math.ucsd.edu/~wgarner/math4c/derivations/trigidentities/sumprod.htm
than ks to both of you! I get it now and was able to use that steps to solve other problems
11K
