What Happens to the Charge on a Grounded Sphere Near a Charged Rod?
  • Context: Undergrad
  • Thread starter Thread starter Coldie
    Concept Physics
When a negatively charged rod is brought near a grounded metal sphere, it induces a separation of charges within the sphere, resulting in negative charges accumulating on the far side and positive charges on the near side. Grounding the sphere allows these negative charges to escape, leaving the sphere positively charged once the rod and grounding finger are removed. The final charge on the sphere is positive due to the loss of electrons, confirming that grounding facilitates charge removal in response to external electric fields.
  • Understanding of electrostatics and charge induction
  • Familiarity with grounding concepts in electrical systems
  • Knowledge of charge separation and movement in conductive materials
  • Basic principles of electric fields and forces
  • Research the principles of electrostatic induction and charge distribution
  • Explore grounding techniques and their applications in electrical safety
  • Study the behavior of conductors in electric fields
  • Learn about the effects of charge removal on conductive objects
Students of physics, electrical engineers, and anyone interested in understanding electrostatic phenomena and charge interactions in conductive materials.
Coldie
A negatively charged rod is brought near a suspended metal sphere. The sphere is 'grounded' by touching it with a finger. The finger and the rod are now removed. What charge will be on the sphere, positive or negative? Explain what happens.
Initially I thought that the finger would remove any induced charge that the sphere took on from the rod, but now I'm questioning that position. Can someone explain to me whether I'm wrong, and if so, how things really work?
Thanks.
When you bring the rod close to the sphere, you induce negative charges on the far side of the sphere and positive charges on the near side. Basically, the electrons on the sphere want to be as far away from the rod as possible. By grounding the sphere you provide a path for these electrons (negative charges) to leave the sphere and this is exactly what they wanted. So the negative charges leave the sphere, making it ...
I see. So if the rod and the finger were both on the same side and then removed, then the change in charge of the sphere would ideally be zero?
  • · Replies 58 ·
  • · Replies 26 ·
14K
