Translation and compression/expansion
  • Thread starter Thread starter gillgill
    Translation
The discussion revolves around the transformations of the function y=√x, specifically focusing on translation and compression/expansion. Participants are exploring how to determine the order of these transformations when applied to the function y=√2x-5.
  • Participants are attempting to clarify the correct interpretation of the transformations, questioning whether to translate the graph first or apply horizontal compression. There is also discussion about the correct form of the function and its implications for transformation.
The discussion is ongoing, with participants providing insights into the effects of translation and compression. Some guidance has been offered regarding the order of transformations, but no consensus has been reached on the best approach.
There appears to be some confusion regarding the notation and the implications of different forms of the function, which may affect the understanding of the transformations involved.
gillgill
i have a question about translation and compression/expansion
y=√x ; y=√2x-5
how do u know u translate 5 units right first or horizontal compression by 1/2 first...?
Y = 2(X^1/2) - 5
if i got that correct
Is that [itex]y=\sqrt{2} x-5[/itex] or [itex]y=\sqrt{2x}-5[/itex]
Daniel.
Exactly the same. There's no difference.
If it involves f(nx+m), then you need to beware of it.
If it involves nf(x)+m, no aware should be made.
In this case, since not the first case, no aware.
If you simply replace x by x-5, the graph will be shifted 5 to the right.
If you replace x by 2x, you will horizontally compress the graph by a factor 2.
So, if you shift and then compress:
[tex]\sqrt{x} \rightarrow \sqrt{x-5} \rightarrow \sqrt{2x-5}[/tex]
and if you compress and then shift:
[tex]\sqrt{x} \rightarrow \sqrt{2x} \rightarrow \sqrt{2(x-5)}[/tex]
o..icic...thx
  • · Replies 67 ·
  • · Replies 21 ·
