Submanifolds vs Manifolds / Immersion vs Charts
  • Context: Graduate
  • Thread starter Thread starter Trifis
    Charts Manifolds
The discussion revolves around the concepts of submanifolds and manifolds, particularly focusing on their definitions, relationships, and the implications of using immersions versus charts. Participants explore the theoretical underpinnings and motivations for introducing submanifolds in the context of multivariable calculus and abstract manifold theory.
  • One participant suggests introducing submanifolds before manifolds as they relate to familiar geometrical objects, proposing that immersions can be viewed as parametrizations of these objects.
  • Another participant questions the logic of defining a "sub-object" before establishing what the "object" is, arguing for a more traditional approach.
  • There is a mention of treating submanifolds of ℝn as a motivation for defining abstract manifolds and their tangent spaces, referencing authors like Gallot-Lafontaine-Hullin and Spivak.
  • Participants discuss the distinction between the intrinsic topology of manifolds and the extrinsic topology of submanifolds, noting that while every manifold can be realized as a submanifold of Euclidean space, this is not immediately clear.
  • One participant posits that the modern definition of manifolds may derive from intrinsic geometry concepts introduced by Gauss and Riemann, rather than solely from parameterized surfaces.
  • There is a suggestion to use "parametrization" instead of "immersion" for clarity, as immersion is viewed as a more general concept.
Participants express differing views on the order of introducing submanifolds and manifolds, with no consensus reached on the best approach. The discussion includes both supportive and critical perspectives on the definitions and relationships between these concepts.
Some participants note that the definitions of manifolds and submanifolds depend on different topological perspectives, which may lead to confusion. The discussion also highlights the historical evolution of the definitions and their implications in modern mathematics.
Trifis
Ok first of all I'd like to mention that I've searched the forum and didn't find anything similar, so hopefully this thread is not unwelcome...
Now as the title suggests, I am interested in a parallelization of the two concepts. Personally I like to introduce the idea of submanifolds prior to that of manifolds, because they can be identified with the geometrical objects (curves, surfaces) handled in regular multivariable calculus. Consequently, the immersion may be described as the usual parametrization of these objects up to the condition about open sets mapping (later defined as homeomorphism in topology).
But manifolds take a different approach, since they require charts (homeomorphic maps from a space of some dimension to the euclidean space of the same dimension) for their definition. Thus, while immersions map points of a coordinate space to the submanifold, the charts operate in the inverse way and project points of a general space onto an euclidean equivalent.
For example: let us consider the 2-sphere. It can be defined as a 2-dimensional submanifold M of codimension 1 by the use of the immersion (=parametrization) φ: U[itex]\subset[/itex]ℝ2→(M[itex]\cap[/itex]V)[itex]\subset[/itex]ℝ3 , (θ,φ)→(x,y,z) , with U and V open sets and φ a hemeomorphism.
Alternatively, the sphere S2[itex]\subset[/itex]ℝ3 with the relative topology is also a topological manifold. Should we make use of the stereographic projection, we acquire two maps (fi: U[itex]\subset[/itex]S2→Vi[itex]\subset[/itex]ℝ3[itex]\subset[/itex]ℝ2 , i=1,2) with differentiable transition maps, which helps us make the sphere this time a differentiable manifold!
Is my train of thought valid so far? Does sth need to be presented more rigorously?
Certainly low dimensional manifolds are easier to think of than large dimensional manifolds but I can see no reason for introducing "sub-manifold" before "manifold". How can you have a "sub-object" before you said what the "object" is?
I think he is referring to "submanifold of R^n". The idea is to treat these objects as a motivation for the definition of abstract manifolds and their tangent spaces. It is the route employed by the authors Gallot-Lafontaine-Hullin, and also Spivak.
to the OP: I advise you to use the terminology "parametrization" instead of immersion because an immersion is a much more general map btw manifolds.
Exactly that is the concept. Submanifolds of ℝn give a first idea about spaces that may be not linear (not even vector spaces) but they interract with linear spaces through maps.
@HallsofIvy have a look at my trivial example and how do I infer the general from the particular.
Yes of course, it is more general, but for an introduction to the topic, isn't it right to think of it as a parametrization and its inverse as the chart ?
The idea of manifold and a submanifold of Euclidean space are technically different since a manifold is defined through an intrinsic topology composed of coordinate charts while a submanifold is defined through the extrinsic topology of Euclidean space.
It is a theorem that any manifold can be realized as a submanifold of Euclidean space but a priori this is not clear.
While parameterized surfaces probably were the first studied manifolds, I would guess that the modern definition of manifold comes from notions of intrinsic geometry discovered by Gauss and Riemann and maybe also from the idea of a Riemann surface which does not come from parameterized surfaces but from finding the natural domain of definition of analytic functions.
  • · Replies 37 ·
  • · Replies 20 ·
  • · Replies 44 ·
  • · Replies 36 ·
  • · Replies 40 ·
9K
